Need a quick help and Hint
Old Apr 19, 2007 | 08:35 PM
dougshatch's Avatar
Default Need a quick help and Hint
Im gonna converted the HARNESS WIRES...do i have to match the wires codes from obd0 and obd1...and that would work? Like black wire with gree stripe on obd0 and blk/gren stipe on obd1 and hook it up together is that right?
Old Apr 20, 2007 | 04:13 AM
escourt23's Avatar
Default Re: Need a quick help and Hint (dougshatch)
You need to find the wiring diagram for YOUR CAR and the ECU you will be using. The wires do not always mate to each other by the colors.
Old Apr 20, 2007 | 04:21 AM
dougshatch's Avatar
Default Re: Need a quick help and Hint (escourt23)
not ecu....HARNESS WIRES
Old Apr 20, 2007 | 05:18 AM
my crx's Avatar
I'm a Jackass
what harnesses you talking about, the ones form your passenger side or any harnesess
Old Apr 20, 2007 | 05:21 AM
dougshatch's Avatar
Default Re: Need a quick help and Hint (dajah_vue)
Engine Harness Wires passanger side not the ECU CONVERSION HARNESS
Old Apr 20, 2007 | 06:50 AM
ludesrv's Avatar
Why are you touching that? OBD0 harnesses can work with OBD1 ecus. Infact most sensors are the same from 88-00.
Old Apr 20, 2007 | 10:43 AM
dougshatch's Avatar
Default Re: (ludesrv)
Engine Harness are different id have to converted it
Old Apr 20, 2007 | 10:47 AM
ludesrv's Avatar
Default Re: (dougshatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougshatch &raquo;</TD></TR><TR><TD CLASS="quote">Engine Harness are different id have to converted it</TD></TR></TABLE>
No you don't. I ran an OBD2 B16 in my OBD0 civic that I converted to OBD1.
If you get an rywire adaptor for obd0 to obd1 you don't have to change anything on your harness.
Read up more.
boomslang
Dec 6, 2010 09:37 AM
richboi
Jun 1, 2009 12:35 PM
therotaryrocket
Oct 12, 2008 06:45 PM
turbotime.
20
May 25, 2003 11:52 PM
