Alpine motorized fold down issue with S2000
I have a Alpine CDA-9851 with a motorized fold down face that I installed in my S2000. I don't know why but when I hit the cd button the face folds down fine, but on the way up it stops just before fully closing. It doesn't look to have any clearance problems. But if I remove the S2000 radio door and shroud it works fine. I also checked the tilt settings on the head unit and they are set to fully closed.
Does anyone have any ideas or suggestions?
Here a pic and some videos
How it should work
http://students.washington.edu...s.AVI
How it doesn't work (I deactivated tilt)
http://students.washington.edu...k.AVI
I think it might just be a sensor issue because it doesn't seem to bump into anything
How it should work
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You are the man, with the pics and vid to a problem. I wish alot would post like this. Now to fix. I seen this to many times and a easy fix is to pull the headunit out. Your going to bust out a file and hit the edges were the cages slides in. There is to much pressure around the unit. This will fix your problem
np, glad to be of service. Its a common problem with radios like that of all makes. Any little bit of bind will cause these problems. Let us know the out come
yellowbastrd
Dec 3, 2001 06:14 PM
