question on how much oil rings replacement cost??
well first will i get reported for this??!! But this guy i know said he will replace my oil rings and all for around $500 dollars and i kinda think its alot but needs some help plz answer one of the questions!! cheea!!
i guess cuz my car smokes when i hit high rpm's and im thinkin its the oil ring on my pistons and yea i think he's gonna take the motor apart and fix the problem in 1 or 2 days?? good or bad deal??
Hondas are notorious for sticky oil rings in high mileage motors. Its an easy job to do, but cleanliness is extremely important. also chances are if you oil rings are bad, the bearings are probably not so hot either. might as well take the extra step, since it will be apart anyways. is the shop clean, or back yard?
ohh its a shop and yea i was plannin on replacing wat needs to be fix but need to know if thats the problem cuz dont wanna fix somthing that doesnt need to be fix you feel me??!!
leak down will not show bad/stuck oil rings!!!! neither will a compression test. Please ask someone knowedgable to look at or work on your motor. I have done my fair share of quick and dirty re-rings. If you are careful its no problem. A moron can turn things ugly very quickly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">ok but damn know im confused bout wats wrong wit my car!!! </TD></TR></TABLE>
maybe not, but it will prove that they are not the cause in most cases.
Yea $500 sounds really cheap if the motor is in the car. You pretty much have to take the whole motor apart. If you have the tools, I would suggest buying a Helms manual and doing it yourself. You'll save $$ and obtain a ton of knowledge along the way.
j0keefe21
11
Jun 22, 2009 04:20 PM
