dumb question '91 crx hf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougshatch »</TD></TR><TR><TD CLASS="quote">just fill it till it starts pouring out the fill hole duuuhhhh</TD></TR></TABLE>
Your the guy removing the coolant lines right?
Anyhoo. Im too lazy to get my little blue crx book so why not just keep checkin the dipstick over and over again like i do?
Jesus you guys. Ok put in about 3.5 quarts then start the car so you can fill the oil filter. Keep it running for about 30-45 seconds to do that. Then shut it off and wait a minute or two to let the oil settle. Then check the dip stick. You will be a little low. I am guessing you dont have a lot of experiance on how much to fill when its low. So just keep adding little bits at at a time and check after a minute or two and see how close you are to the second dot. Ocne you get to the second dot your set.
bigbail
Apr 22, 2010 06:08 AM
sweetchick69
13
Oct 30, 2005 04:32 PM
GS8HFL21
10
Apr 15, 2004 05:28 PM
