New Rocker to replace VTEC? Bueno or no?
Old Apr 19, 2007 | 04:30 PM
djtsmith007's Avatar
Default New Rocker to replace VTEC? Bueno or no?
Anyone seen or use these before?
New Honda Roller Rocker
This Special "Aluminum-Magnesium Roller Rocker System" was designed and developed by Ferrea to replace the factory "Steel Rocker Arm System" and eliminate the V-TEC Function. Factors such as weight, mass moment of inertia, deflection, and cycle-durability are taken into account throughout the design and testing process The new RR1002 Single roller bearing weights only 143 grams, which the OEM unit weighs 110% more. These new rollers rockers can only be used with Ferrea camshafts, which eliminates the two side lobes of the camshafts to one single lobe of the camshaft. Applications for Acura (B17A1, B18C1-C3, B16A1, B16A3, H22A1-A4).
Ferra Rocker
and here
Products Page
CraneCams Version
http://www.cranecams.com/index...=2017
And the special CAMS
http://www.cranecams.com/index...=2054
Old Apr 19, 2007 | 04:38 PM
doood's Avatar
been there done that
Default Re: New Rocker to replace VTEC? Bueno or no? (djtsmith007)
nothing new. check the all motor forum.
mossman77
Aug 31, 2016 05:52 AM
Corksil
24
Jun 3, 2011 09:22 AM
guysensei
Engine Management and Tuning
Oct 9, 2008 09:15 PM
Jimihendrix
Honda S2000
31
May 31, 2007 06:59 AM
