asr eg subframe reinforcement brace into 90 crx fitting
Old Apr 19, 2007 | 02:39 PM
Double Trouble's Avatar
Default asr eg subframe reinforcement brace into 90 crx fitting
hi i want this brace so bad but they dont make it for a ef.But i have noticed that the lower rear tie bars fit on the ef from an eg ,so will the asr subframe brace from an eg fit on an crx?Thanks.
Old Apr 22, 2007 | 06:40 PM
Default Re: asr eg subframe reinforcement brace into 90 crx fitting (Double Trouble)
bump anyone
Old Mar 20, 2008 | 05:07 PM
defnu's Avatar
it'd be nice to know
Old Mar 20, 2008 | 05:54 PM
socalrex88's Avatar
i made the same thread but guess what.....no one answered....i hella want to kno if its possible!
Old Mar 20, 2008 | 09:01 PM
GSR CRX's Avatar
Default Re: asr eg subframe reinforcement brace into 90 crx fitting (socalrex88)
it is very so possible. i also want one but funds just arent available right now.
Old Mar 20, 2008 | 09:06 PM
GSR CRX's Avatar
Default Re: asr eg subframe reinforcement brace into 90 crx fitting (GSR CRX)
if owner of this car wants me to take down this pic let me know.
now that that is out of the way.this is marlons crx with the asr bar. so, as pictures dont lie, there you go. it fits. not all the blots are used though because they are not present on the crx subframe. holes may probably be drilled to accomodate for the missing bolts but do not take my word for it for i dont have one myself.
Modified by GSR CRX at 12:03 AM 3/22/2008
Old Mar 21, 2008 | 09:21 AM
dem0nk1d's Avatar
that's very clever. i wonder if any other company's will start making copies or versions for the ef's.
Old Mar 21, 2008 | 09:35 AM
thevtecnician's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR CRX &raquo;</TD></TR><TR><TD CLASS="quote">if owner of this car wants me to take down this pic let me know.
now that that is out of the way.this is marlons crx with the asr bar. so, as pictures dont lie, there you go. it fits. not all the blots are used though because they are not present on the crx subframe. holes may probably be drilled to accomodate for the missing bolts but do not take my worf for it for i dont have one myself.
The main purpose of the asr rear subrame reinforcement bar is to reinforce the rear subframe to allow safe use of a bigger rear sway bar. Of course it will technically fit but will it rip out under heavy loads is a better question to ask yourself. To use it without using all the bolt holes is completely unsafe to do
Old Mar 21, 2008 | 10:21 AM
Joe...'s Avatar
Default Re: (thevtecnician)
isnt the point of the missing holes to put the bushing around the sway bar?
which is missing in this picture?
Old Mar 21, 2008 | 10:34 AM
fireant's Avatar
Default Re: (Joe...)
What is the point of putting these on EF/CRX/DAs?
Old Mar 21, 2008 | 12:01 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
There is no point..... having a rear subrame brace missing bolts is like having a five point harness with missing straps....
https://honda-tech.com/zerothread?id=1146145
^^the right way to put a rear sway in one of our cars.
Old Jul 6, 2009 | 07:41 AM
Vinsanity88's Avatar
ITS FINALLY OUT!!!!!!!!! Just saw it online!! google ASR Rear Sub Frame CRX....
airmaxbri
Jul 4, 2010 12:06 PM
Double Trouble
Feb 24, 2007 09:42 AM
Acme2eg6
Jul 13, 2003 08:04 PM
