1/4 mile time with gsr trans
Old Apr 19, 2007 | 02:24 PM
BLUCIVICSl2's Avatar
Default 1/4 mile time with gsr trans
hey guys i have a 93 cx with a built gsr swap about 190hp to the wheels. i am running an LS trans currently and my question is, how much faster do you think i would run the quarter mile with a gsr or b16 trans instead of the LS
Old Apr 19, 2007 | 02:25 PM
Default Re: 1/4 mile time with gsr trans (BLUCIVICSl2)
also how much should it cost to swap out my trans for another one labor wise
Old Apr 19, 2007 | 02:27 PM
bump
Old Apr 19, 2007 | 02:32 PM
anyone?
Old Apr 19, 2007 | 02:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
9's.
Old Apr 19, 2007 | 02:40 PM
Default Re: 1/4 mile time with gsr trans (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">9's.</TD></TR></TABLE> what?
Old Apr 19, 2007 | 02:42 PM
uglyasscivic's Avatar
Old Apr 19, 2007 | 02:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
I meant its getting closer to 9 o'clock. sorry I posted in the wrong thread, my bad.
Old Apr 19, 2007 | 03:53 PM
k so anyone know the answer?
Old Apr 19, 2007 | 05:30 PM
high_revs's Avatar
lol not much faster....go get a type arrrrr trans
Old Apr 19, 2007 | 07:07 PM
Innes's Avatar
Default Re: (h2b_eg8)
your best bet is to get a liberty gearset with 4.9 final drive, gforce shifter and nitro driveline with spool for the best results...that will knock about 0.2 seconds off your current time...
...very cost effective too !!!
Old Apr 23, 2007 | 02:08 PM
Default Re: (Innes)
.2 thats it? anyone else? im debating switching the trans vs. throwin an LSD on the LS trans
Old Apr 23, 2007 | 02:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">lol not much faster....go get a type arrrrr trans</TD></TR></TABLE>
too much $
Old Apr 23, 2007 | 09:06 PM
all-mtr-teg's Avatar
he's better off building his tranny with some mfactory parts instead of buying a hype r tranny
Old Apr 24, 2007 | 06:42 AM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I meant its getting closer to 9 o'clock. sorry I posted in the wrong thread, my bad. </TD></TR></TABLE>
LMAO
Honestly, you could probably see gains somewhere around .2 - .6 in the 1/4. Maybe more even. Depends on a lot.
As for labor price. I have no idea. Go check local garages that do work. Or you can put the tranny in yourself.
Old Apr 24, 2007 | 09:41 AM
builthatch's Avatar
MiG-21 superfan
you won't get a serious answer in here unless you are making several hundred horsepower.
Old Apr 24, 2007 | 11:18 AM
Default Re: 1/4 mile time with gsr trans (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">you won't get a serious answer in here unless you are making several hundred horsepower.</TD></TR></TABLE>
why?
and what would it depend on? If i could drop .6 in the quarter id definitely do it, .2 aint really worth it considering id need to get it installed and bring it to Evans to get retuned
Old Apr 24, 2007 | 11:20 AM
bump
Old Apr 25, 2007 | 07:36 AM
TDautowerkes's Avatar
the nitro driveline is good.... includes a spool and all even the hubs....
Old Apr 25, 2007 | 04:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 1/4 mile time with gsr trans (TDautowerkes)
Have you thought about the B2D kit?
Old Apr 25, 2007 | 05:15 PM
Blown90hatcH's Avatar
Go run the car how it sits at the track with the LS tranny. Look at your rpm in 4th gear (.....ehhhh...LS tranny......hhhhmmm..........might still be in 3rd gear.....) at the end of the track. Ultimately you want to be around peak rpm(ASSuming your peak rpm is around your peak power) at the end of the track in 4th gear. Holla back with your track results and you will probably be able to answer your own question.
Old Apr 25, 2007 | 11:07 PM
CETVTOGEM's Avatar
Default Re: 1/4 mile time with gsr trans (Blown90hatcH)
i lost 2 tenths from changing from gsr trans to b16 and thats with 155whp and 4500ft. elevation..
so i guessing you'll lose a 4tenths+
Old Apr 25, 2007 | 11:16 PM
1FSTHATCH's Avatar
Default Re: 1/4 mile time with gsr trans (CETVTOGEM)
With the power level your flirting with i'd look into the mark williams setup..
Old Apr 28, 2007 | 07:39 AM
Default Re: 1/4 mile time with gsr trans (1FSTHATCH)
what is the mark williams set up, and what is the b2d kit?
Old Apr 28, 2007 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CETVTOGEM &raquo;</TD></TR><TR><TD CLASS="quote">i lost 2 tenths from changing from gsr trans to b16 and thats with 155whp and 4500ft. elevation..
so i guessing you'll lose a 4tenths+</TD></TR></TABLE>
so maybe i should go with a b16 trans then?
