brake light turns on when i shift????
Old Apr 19, 2007 | 01:45 PM
994drLS's Avatar
Default brake light turns on when i shift????
whenever i shift at higher RPMs 5000+ either right before or when i put the clutch in the brake light turns on. why is this happening???
also when i'm driving around theres this strange sound coming from my wheels or somewhere from under my car, like this odd sort of ticking sound, dont know how to describe it. anyone know what this is?
Old Apr 19, 2007 | 02:43 PM
JasonST's Avatar
Default Re: brake light turns on when i shift???? (994drLS)
Ur brake switch above the brake pedal is probly loose and really close to the pdel so when u shift ur car jerks a tad bit but causes the switch to activate, theres a way to loosen and tighten the switch, just look at it underneath the dash above the brake pedal u'll se what i mean. As for the ticking noise, could be ur valves in need of a valve lash job.
Old Apr 19, 2007 | 03:23 PM
994drLS's Avatar
Default Re: brake light turns on when i shift???? (JasonST)
its not the brake lights, its the e-brake light that lights up
Old Apr 19, 2007 | 03:39 PM
994drLS's Avatar
okay, i just went for a drive, and now whenever i stop completely and go in 1st gear, the brake light pretty mcuh stays on until i shift, then it doesnt turn on again. any ideas???
Old Apr 19, 2007 | 04:35 PM
schardbody's Avatar
captain obvious says you are low on fluid and the float in the master cylinder is being moved slightly as your car moves/stops.
check the fluid level.
Old Apr 20, 2007 | 11:23 AM
994drLS's Avatar
now its not only first, but second too??????
Old Apr 20, 2007 | 11:25 AM
mike-y's Avatar
check your fluid level
Old Apr 20, 2007 | 01:45 PM
davidluko's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">captain obvious says you are low on fluid and the float in the master cylinder is being moved slightly as your car moves/stops.
check the fluid level.</TD></TR></TABLE>
What I was going to say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994drLS &raquo;</TD></TR><TR><TD CLASS="quote">its not the brake lights, its the e-brake light that lights up</TD></TR></TABLE>
The e-brake light is the same as the brake light.
Old Apr 21, 2007 | 09:01 AM
994drLS's Avatar
Default Re: (Hatch_R)
not my brake lights, its the BRAKE light on the gauge cluster that lights up
Old Apr 21, 2007 | 09:20 AM
Damon Reeves's Avatar
Default Re: (994drLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994drLS &raquo;</TD></TR><TR><TD CLASS="quote">not my brake lights, its the BRAKE light on the gauge cluster that lights up</TD></TR></TABLE>
Sell the car.
Old Apr 21, 2007 | 10:29 AM
davidluko's Avatar
Yes, we understand. It says "BRAKE" in red on the gauge cluster. That turns on if your hand brake is up and if the fluid level in the brake fluid reservoir is low.
91b18a1ls
Mar 19, 2011 10:24 PM
cyclonedr
Oct 7, 2009 01:47 PM
BigAnteg
19
May 21, 2009 05:44 AM
geneva
Jun 11, 2008 01:46 PM
ludaboy93
Feb 20, 2006 04:22 AM
