CAR STILL GETS HOT?
Old Apr 19, 2007 | 01:44 PM
kyle4201605's Avatar
Default CAR STILL GETS HOT?
I CHANGED THE WATER-PUMP AND FANS AND THERMOSTAT AND STILL HOT. ANYONE MIGHT KNOW WHY?
Old Apr 19, 2007 | 01:56 PM
VTteg's Avatar
Default Re: CAR STILL GETS HOT? (kyle4201605)
Did you properly bleed the system?
And please don't type in all CAPS.
Old Apr 19, 2007 | 01:57 PM
Default Re: CAR STILL GETS HOT? (VTteg)
yes I bleed it. and still
Old Apr 19, 2007 | 02:13 PM
o0oz's Avatar
bad head gasket? what about fan?
Old Apr 19, 2007 | 02:15 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: CAR STILL GETS HOT? (o0oz)
Radiator could be clogged.
Old Apr 19, 2007 | 02:19 PM
red99teggy's Avatar
this happened to me and it turned out to be that my raidiator was clogged. after they flushed it with some stuff it worked like a charm
Old Apr 19, 2007 | 02:20 PM
Default Re: CAR STILL GETS HOT? (red99teggy)
alirght i'll try it
Old Apr 19, 2007 | 05:43 PM
Sam92Teg's Avatar
Any chance your temp sensor that operates the gauge is faulty? How high is it reading?
Old Apr 20, 2007 | 07:42 AM
Default Re: CAR STILL GETS HOT? (Sam92Teg)
its reading over half. and it doesn't go down. I even have two fans.
Old Apr 20, 2007 | 07:55 AM
mac_24_seven's Avatar
IF the fans are on and the temp needle is still up.. I"m leaning towards a malfunction there.
Try this...
I assume it doesn't take long before the car gets " hot" right? So, with it cold, take off the radiator cap and let it idle.
Keep a look out at the water, it shoudl be kinda sitting there. Dip yrou finger peridically in it to test for warmth.. It'll slowly heat up untill your thermostat opens, then the water will start circulating and it'll get hot.
If The above never happens and the water stays cool/warm (of course its gonna warm some, the engine bay is hot) you have a stuck thrmostat. DO NOT drive it untill you replace it.
Try that and let us knwo what happens.
But please, dont take off the cap when the car is hot and scald yoruself :S
Old Apr 20, 2007 | 08:16 AM
b20acura's Avatar
Default Re: CAR STILL GETS HOT? (mac_24_seven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">IF the fans are on and the temp needle is still up.. I"m leaning towards a malfunction there.
Try this...
^ yes do what he says and do not drive it until you fix the problem. i was running my boss' 4runner a few months ago. something was malfunctioning with his cars cooling system and it got too hot, even though the temp gauge didnt show it, and ended up having to replace the engine.
TooFastVTEC
11
Jul 20, 2012 11:53 AM
agdclassic
Honda Civic (2001 - 2005)
May 23, 2011 07:25 AM
stevenDAtegra
Jul 23, 2009 12:32 PM
buzlink
10
Mar 25, 2005 01:10 PM
trashkilla
Oct 15, 2004 11:16 AM
