is it worth it ?
Old Apr 19, 2007 | 10:34 AM
crito07's Avatar
Default is it worth it ?
i found a 89 4door wit 140,000 but they say only 3 cyls are workin and failed emissions but it runs strong . so is there any way i can get the 4th to work? is it even worth my time?
Old Apr 19, 2007 | 10:50 AM
Loserkidwac's Avatar
Default Re: is it worth it ? (crito07)
Uhm...if its only running in 3 cyl it isn't running storng....its worth less than $500 in my opinion would have to have a perfect rust free body with good paint to be worth it honestly, a new/replacement D series would be cheap but depends on your mechanical skills...
Old Apr 19, 2007 | 10:59 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crito07 &raquo;</TD></TR><TR><TD CLASS="quote">they say only 3 cyls are workin [...] but it runs strong</TD></TR></TABLE>
Umm, no.
If it's running on 3 cylinders, there is a 99% chance it needs another engine.
If you can do an engine swap yourself, and the body looks clean enough to last a few years, offer them a couple hundred bucks. If not, find something else.
Old Apr 19, 2007 | 11:02 AM
crx18c1's Avatar
no its not....find yourself a clean EF that is runningn good...they are out there just look...
GL
Old Apr 19, 2007 | 11:22 AM
crito07's Avatar
ok its only for $200 how much for a d series u think?
Old Apr 19, 2007 | 11:36 AM
CRX Toad's Avatar
D-series = $200-$500
Old Apr 19, 2007 | 12:03 PM
Targa250R's Avatar
be professional
Default Re: is it worth it ? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">D-series = $200-$500</TD></TR></TABLE>
Don't let the low purchase price of an engine fool you.
You will still need general maintenance items such as the timing belt & tensioner, water pump, accessory belts, clutch & pressure plate, rear main seal, air/fuel/oil filters, engine oil, trans oil, and coolant at a minimum. You should budget at least an extra $100 for misc. items you may need during the swap as well.
And that's just for the engine. There's no telling what else the car needs (brakes? axles? fuel lines? etc.).
Old Apr 19, 2007 | 12:07 PM
crito07's Avatar
thanks everyone
Old Apr 19, 2007 | 12:17 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crito07 &raquo;</TD></TR><TR><TD CLASS="quote">ok its only for $200 how much for a d series u think?</TD></TR></TABLE>
How is the body ? Do a compression test and see if that cylinder is bad on a compression.
A cylinder not working could be something simple like a spark plug wire, but depending on how long its been like that, could be bad
Old Apr 19, 2007 | 12:48 PM
89efDUSTY's Avatar
Default Re: (crito07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">D-series = $200-$500</TD></TR></TABLE> just look around i got my d16a6 perfect condition with manifolds and sensors for 100, just bad distributor
Old Apr 19, 2007 | 02:24 PM
crito07's Avatar
Default Re: is it worth it ? (RCautoworks)
thats what i was thinkin bout i dunno ima have to go check it out
Old Apr 19, 2007 | 03:38 PM
dumped4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crito07 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinkin bout i dunno ima have to go check it out</TD></TR></TABLE>
ur asking if i car is worth it but u havent even looked at it?
whats wrong with people these days......
i think u just wasted every1's time that tried to help u out...
for that i hope its rusted out, has nasty interior, and looks like some1 took a baseball bat to the outside of it.... that way the engine doesnt matter
and some1 wasted ur time
aleks708
Feb 22, 2008 07:01 PM
95turbohatch
Honda Motorcycles
27
Jan 27, 2005 02:31 PM
kar_the_terrible
16
Jan 6, 2005 02:20 PM
BenB
Oct 21, 2004 05:50 PM
gezer
May 5, 2003 06:22 PM
