no spark in one cylinder
Old Apr 19, 2007 | 07:44 AM
bshshondaman06's Avatar
Default one cylinder not working
i have a gsr and just installed a jrsc. now the #4 cylinder doesnt get any spark
i put all new plugs in the engine all gapped at .32 and one of them is clean where as all of the others have black on them. it smells like fuel the cylinder just wont fire.
i recently replaced the spark plug wires with oem honda wires and am using ngk plugs. i swithced plugs and that cylinder still wouldnt fire.
Modified by bshshondaman06 at 9:58 AM 4/19/2007
Old Apr 19, 2007 | 07:53 AM
mac_24_seven's Avatar
Default Re: no spark in one cylinder (bshshondaman06)
If you've switched plugs and it doesn't work still along with new wires... You've got to go backwards.
Something in the distributor then?
Have you tested ot see if there is ANYTHING going through that spark plug? Any voltage at all?
Old Apr 19, 2007 | 07:56 AM
Default Re: no spark in one cylinder (mac_24_seven)
ive switched plugs and wires it still wont fire but the other 3 work.
Old Apr 19, 2007 | 08:57 AM
ok.. so i checked the plug agaisnt the head and it does spark.. so ill now check the resistor box then the wiring.
Old Apr 19, 2007 | 09:01 AM
delsolo95
Jun 13, 2011 06:15 AM
2000h22a
Aug 4, 2008 12:48 PM
b16b18
Sep 6, 2006 12:56 PM
sparkplugmess
Jan 9, 2006 03:05 PM
red civic standard
Jul 18, 2002 03:13 AM
