no spark
Old Apr 19, 2007 | 07:30 AM
honda_tuner_2007's Avatar
Default no spark
my uncle has a 1993 civic dx and it has no spark.it has new dist., rotor, plugs,wires.what could be the cause of no spark??went into store and came back out and it wouldnt start?
Old Apr 19, 2007 | 07:48 AM
pdiggitydogg's Avatar
Easiest places to check:
Battery
Ecu connection
Grounds (especially @ the water neck behind the block)
Starter
Old Apr 19, 2007 | 07:57 AM
Default Re: (pdiggitydogg)
we checked all that as well.coulf it possibly be the ingniton coil??
Old Apr 19, 2007 | 08:39 AM
instructor74's Avatar
Default Re: (honda_tuner_2007)
since you didn't replace that when you changed out the dizzy more then likely. no spark is most commonly caused by the coil going bad or the ignighter
Old Apr 19, 2007 | 08:53 AM
Wharbone's Avatar
When I had a similar problem, it was my coil/ignitor.
Old Apr 19, 2007 | 09:12 AM
som3on3_10's Avatar
^^^Yea what he said. Instead of purchasing a new coil or ignitor, I would just get a new dizzy from Distributor King.
Old Apr 19, 2007 | 09:43 AM
Default Re: (som3on3_10)
ok thanks for the help
Thecargoddess
Jul 3, 2024 07:09 PM
spoonhbk11
11
Jun 9, 2019 07:03 PM
egluism33
May 25, 2008 06:17 PM
crxzc
Jun 9, 2002 06:50 PM
