Adj Brake Proportional Valve?
Converting to rear disc soon, do I really need to get an adj valve or will I be ok w/ the stocker? Where is the stock one? Will the DA Teg 4040 fit/work? Looked at the ones Summit Racing sells but wasn't sure if any of them would work.
- 98 Coupe, LX
- 98 Coupe, LX
you don't need an adjustable proportioning valve, a stock proportioning valve will be just fine. You will want to switch from the stock one for drum brakes to a stock one from a rear disc brake setup though.
88crxvtec
Mar 2, 2014 04:34 AM
PupaScoopa
Aug 29, 2003 03:26 PM
