Yet another Tranny question!!! I have 24 hours before landlord tows my car out the GARAGE!
Sad but true!!! He told me I have 24 hours to fix the car and get it out and Im having trouble with the following:
-Axle Hub that connects to half shaft will nto pop loose
-If I take out the half shaft Bracket that hold it to the block, will it it pop out from the TRANS???
-I took out all the 17mm bolts from around the trans, Is there anything other than the Half shaft holding the tranny in place??
-*************IMPORTANT NOTE***************
If there is anyone in the VA area that wants to make some money$$$$ helping me to get the tranny out then I would gladly appreciate it!!! Thanks Guys
There is one on the opposite side of the tranny on the back of the motor, on the the side facing the drivers side.
Use Pry to pop it out, it would pop out when u use PRY...i fix my hatch yesterday and i use screwdriver and it pops out anything wrong with the trans?
wish i had the day off, i'd come help.. but like others have said, use a pry bar and instead of just constant pressure, you've got to kind of "pop" it to get it off.
pry bar is like a big flat head scrwwdriver. Stick it in between the half shaft and axle and pry them apart
did you take the 14mm bolts that hold the halfshaft in place?
Well I'll be working on it @6pm anyway when I get off of work...
the 14mm for the bracket that holds the Halfshaft in place??? those 14mm's??
yea just take off those 14mm. You have got to remove the halfshaft to drop the trans. Get a long flat head and stick in inbetween the axle and the intermidate shaft right were the axle goes in and pry at it hard. Some times they are a pita.
If I were you I would find someone with a fixed up Honda and see if they could help you. Fixed up, I don't mean ricey, just something clean. I would just start asking people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me »</TD></TR><TR><TD CLASS="quote">wish i had the day off, i'd come help.. but like others have said, use a pry bar and instead of just constant pressure, you've got to kind of "pop" it to get it off.</TD></TR></TABLE>
+1, if I'd had any advance notice I could swing down and help you out, but as it sits I've got a **** ton of work to do.
I'll see if I can't get finished moving my stuff with the girlfriend and help you out tonight around 8:30 if possible. PM'ing you my cell #.
well isn't that what Honda-tech is for right?? Anyhow Im going to try it again tonight and if nothing is accomplished I guess my car will be towed...
BUMP for somenoe who can help me out! would be great! Thanks
did you remove the starter? one of the starter bolts goes through the transmission into the block
Yes there is one bolt that I can see that I can't get too.....I think there is two right??
Dude man don't give up your car. Just find someone to help you. It isn't worth your car getting towed. Even someone that works on american cars anyone, well most, can help you that know about cars.
ok I know what they are....I think I have on but the other is really hard to get out.....
I'm not a tranny guru, but if it's just your third gear syncro, couldn't you just drive in second gear to somewhere else. Or even put it in neutral and push it across the street. I'm just saying as a last ditch effort, get it off his property and tell him to **** off.
Yeah bro im trying to get things done today...Its just prices at shops are CRAZY and I know I can do especially with honda-tech....its just Im in such a rush now..because I have had my car in there since Tuesday.....
Im stressing out....I hope I can finish everything when I get off in 20 minutes....
Well if anyone can help don't hesitate to PM me or Call
240-286-3365
Thanks
240-286-3365
Thanks
UPDATE********
Ok so I got the FREAKIN TRANNY OUT!!! THANK GOD!!!!
NOW I HAVE ANOTHER PROBLEM! Im replacing motor mounts as well as the tranny.....OK well THE FREAKING REAR motor mount will not budge....why??
HOW IN THE HELL DO YOU GET behind the back of the motor mount so I can take out that 14mm????
I cannot find anyway...WTF!
here is the pic....sorry the pic sucks....
Any suggestions??
Any suggestions??
