B16 SIR in CRX HF
I Did A B16 in my CRX HF and when it first got done it was throwing a TPS light and Vtec malfunction and It would never go past 7000 rpm. Now when it's cold it does it but once it warms up it will go to 8200. You can hear my Vtec kicking in and out when it is only going to 7000. Does someone know what it could be?
we need some more info. Did you do the swap yourself? What OBD are you? What ecu are you using? What guides did you use for wiring if you did the wiring yourself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PleaseKeepOffDunes »</TD></TR><TR><TD CLASS="quote">prob OBD0...
Based on what information? It's not uncommon to run OBD1 in an EF.
</TD></TR></TABLE>Based on what information? It's not uncommon to run OBD1 in an EF.
on my b16 rex you cant rev it passed 7grand when its cold but after it warms up its fine.....i think its a good thing to have so you dont blow your **** up....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ox0speedfreak0xo »</TD></TR><TR><TD CLASS="quote">yea most of the time but sometimes when im racing or beating on it i can hear the vtec kicking in and out</TD></TR></TABLE>
This is why I will never buy a used engine from an HT'er.
yes we did the swap, The ECU is PR3, OBD 0, and the wiring we used a hasport sub harness and my brother in law did the rest of the wiring. I know when we first got done the vtec didnt work at all the mike found the wires in the harness for the vtec were backwards so we switched them
stegs
Mar 21, 2008 09:59 AM
s2000june
Jan 1, 2005 07:43 AM
