ls swap in 95 hatch
Old Apr 18, 2007 | 09:14 PM
lowliferanger94's Avatar
New User
Default ls swap in 95 hatch
i recently purchased a 95 vx hatchback. It came with a LS motor and GSR 5spd. trans. The ecu I received with the car for the swap was for an automatic. I was wondering what type of ecu I could use instead that didn't cost like thousands of dollars, or if I would just be better off just getting the one for the automatic re-flashed. I plan on building the motor up and putting a turbo with low boost(8-12lbs). I'm somewhat new to the tuner scene so if anyone has any advice it would be much appreciated. Thank you for any help/advice.
Old Apr 18, 2007 | 09:41 PM
2wheelhunter's Avatar
Default Re: ls swap in 95 hatch (lowliferanger94)
that ecu would work fine.. it may run in limp mode though.. you can have the ecu converted for like 15 bucks plus shipping at http://j-k-tuning.com/
Old Apr 18, 2007 | 09:42 PM
fmrprojects's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowliferanger94 &raquo;</TD></TR><TR><TD CLASS="quote">i recently purchased a 95 vx hatchback. It came with a LS motor and GSR 5spd. trans. The ecu I received with the car for the swap was for an automatic. I was wondering what type of ecu I could use instead that didn't cost like thousands of dollars, or if I would just be better off just getting the one for the automatic re-flashed. I plan on building the motor up and putting a turbo with low boost(8-12lbs). I'm somewhat new to the tuner scene so if anyone has any advice it would be much appreciated. Thank you for any help/advice. </TD></TR></TABLE>
get a 94-95 integra p75 and get it chipped for crome so you can run your turbo later
Old Apr 19, 2007 | 07:47 PM
New User
Default Re: ls swap in 95 hatch (fmrprojects)
Thanks for the information you have listed. However like I said I don't know to much about tuners yet. Sorry to waist your time with what is probably dumb questions but your saying all I do is install the p75 into my existing ecu to make it m/t compatible? Then get it (crome chipped?) for the turbo install? Again I apologize if I am a bother with these questions. Any and all help is greatly greatly appreciated. Thanks again.
jikespingleton
Dec 2, 2006 04:18 PM
**DOHC HaTcH**
Apr 19, 2006 05:29 PM
