RPM AND MILEAGE OFF
Old Apr 18, 2007 | 08:54 PM
dc2long's Avatar
Default RPM AND MILEAGE OFF
when i had my previous gsr, 5th gear at 80mph would be exactly at 4k rpm. i sold
it a while ago and got a new one.
my new gsr goes 80mph at about 4100-4200 rpm in 5th gear. what could be wrong
with it? the previous owner use to put 87 octane in it and 5w40 oil.
when i bought the car, i replaced the clutch and pressure plate and put in mobile 1
oil and clean my gas tank with those techron bottles and only use 91 octane.
any inputs?
Old Apr 18, 2007 | 10:33 PM
mtpktz.'s Avatar
Default Re: RPM AND MILEAGE OFF (LTgsr)
Your tach could be off, which is the most likely.
Although, the previous owner using 87 octane in a 91+ ONLY car could cause damage far worse than your revs being off by a 1,000 or two.
Old Apr 18, 2007 | 11:21 PM
1.8L_allmotormilitia's Avatar
motor is probably harmed by using the 87 gas. god knows how long he used it for.
Old Apr 18, 2007 | 11:39 PM
dc2long's Avatar
Default Re: (1.8L_allmotormilitia)
hes had the car for about 3 years.
could anything be wrong with the valves? should i get my valves adjusted?
Belts?
he told me his uncle changed the belts but he didnt have any paperwork. btw he
didnt know anything about the car, thats why he used 87 octane. he didnt even
know what vtec was.
Old Apr 19, 2007 | 05:31 AM
WookinPaNub's Avatar
Default Re: (LTgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LTgsr &raquo;</TD></TR><TR><TD CLASS="quote">he didnt even know what vtec was.
He's not alone.........
Old Apr 19, 2007 | 06:55 AM
Padawan's Avatar
Darth ModerVader
Default Re: RPM AND MILEAGE OFF (mtpktz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. &raquo;</TD></TR><TR><TD CLASS="quote">Your tach could be off, which is the most likely.</TD></TR></TABLE>
Yes, or the speedometer.
Anyone else suggesting that the issue has <u>anything</u> to do with improper fuel, engine damage, etc. is 100% incorrect. It wouldn't matter how "damaged" the engine was, if it was spinning at a certain RPM (and assuming the clutch is fully engaged), there is only one corresponding road speed per gear, and that is determined by the transmission ratios and the tire size. Conversely, even with a built, 400 whp turbo motor, if you were running the stock transmission, you'd still be moving at the same speed per RPM as you would with a stock setup.
Old Apr 19, 2007 | 07:14 AM
Lauj87's Avatar
what size tires are you using? stock spec tires are 195/50/15. The size of your tires play a big factor in speed and rpm's. with my 205/45/16 at 4000 rpm's i would be going 83-84. but speedo showed i was going 80mph. i tested it one one of those police radar things they have on the side of the freeway sometimes.
Old Apr 19, 2007 | 07:18 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">what size tires are you using? stock spec tires are 195/50/15. The size of your tires play a big factor in speed and rpm's. with my 205/45/16 at 4000 rpm's i would be going 83-84. but speedo showed i was going 80mph. i tested it one one of those police radar things they have on the side of the freeway sometimes. </TD></TR></TABLE>
The tires do indeed play a role in actual speed, but I believe the poster is asking about indicated speed, which wouldn't change regardless of the tire size.
airikkCRX
Feb 7, 2009 01:10 PM
DBAl
Nov 20, 2007 09:36 AM
-Championship-
Jul 14, 2006 06:17 AM
da5785
Aug 21, 2005 04:00 PM
sleepyIntegra
Jul 21, 2004 02:31 PM
