need new radiator? opinions?
Old Apr 18, 2007 | 06:25 PM
stemiched's Avatar
Default need new radiator? opinions?
well my radiator has a leak that just got bigger, and i dont feel like fixing it agean so im getting a new one.
my uncle works at a parts store so im going to get an oem one.
i want a half size radiator because im doing a turbo swap soon.
i figure why buy the same one i have if i can get better
i heard that 94 neon radiators worked so i ordered one but i got a full size, i called him and told him that it was a dif. one i wanted, he went on the comp. and sead there is no smaller one for a 94 neon...
anyway, so that method is out of the question.
im most likely going to get a 92 si eg civic rad. the half size duel core radiator.
but i wanted to confirm that this was the best method. has anyone found a better half size rad?
i beleave i head that 02 gti radiators work well but i forget exactly what i was told...
Old Apr 18, 2007 | 06:34 PM
91ed9's Avatar
Default Re: need new radiator? opinions? (stemiched)
95-99 neon NON AC radiator is the half radiator
or you can get an eg rad but its a little bigger you might have to cut your rad support or have it lean
Old Apr 18, 2007 | 06:35 PM
91ed9's Avatar
Default Re: need new radiator? opinions? (91ed9)
although the neon doesnt have a pressure cap you will need to get an inline one from a parts store
Old Apr 18, 2007 | 06:38 PM
stemiched's Avatar
yea i know all that info already, but according to the parts store comp. the half size neon rad. doesnt exist, i assume they just dont carry it... so im just dropping that idea... i know i could get it somewhere else but the price differance is an 80$ differance, so i m deffinately getting an oem that is carried by this part store.
i wanted to confirm that the eg was the best way.
and she if anyone else knows anything about the gti rad...
Old Apr 19, 2007 | 05:04 AM
JustAnotherRex's Avatar
Del Sol VTEC dual core half FTW; although frankly, if you don't want to lean or use a new crossmember, I'm out of solutions for ya
Old Apr 19, 2007 | 05:53 AM
stemiched's Avatar
Default Re: (JustAnotherRex)
i didnt really want to do much chopping or fabricating of anything but it looks like thats what im going to have to do. the del sol vtec one is the same as the civic right?
Old Apr 19, 2007 | 07:29 AM
stemiched's Avatar
Default Re: (stemiched)
are all 92 civic si's half rads or is it only non a/c ones or something like that?
will the ef hoses work fine with the 92 si half rad?
are there any write ups on how to put it in? i searched and didnt find any...
Old Apr 19, 2007 | 08:17 AM
wickedEFguy's Avatar
I've gone through the hassle of trying to use a 92-95 dual core civic radiator on the stock cross member since I'm B16 turbo'd but it has a slight lean.
From what I know the neon radiator can be used for you have to buy a water neck for it then cut the hoses to place it.
For the money I'd get a Full-race traction bar and the PWR radiator, As soon as I have enough money this is the next modification I'm getting.
Do it right the first time if you're looking for more room.
Old Apr 19, 2007 | 08:20 AM
89efDUSTY's Avatar
check out RCautoworks half size with slim fan 125 shipped to your door...awesome stuff i just got mine yesterday, seriously like one of the best HT buys for me
Old Apr 19, 2007 | 08:22 AM
stemiched's Avatar
Default Re: (89efDUSTY)
i just ordered my 92 half rad, im going to pick it up later today, should be putting it in this weekend.
Old Apr 19, 2007 | 08:26 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">i just ordered my 92 half rad, im going to pick it up later today, should be putting it in this weekend. </TD></TR></TABLE> you have a stock crossmember?
Old Apr 19, 2007 | 08:31 AM
stemiched's Avatar
yea i do... ill just have to modify it wont i...
Old Apr 19, 2007 | 08:33 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">yea i do... ill just have to modify it wont i...</TD></TR></TABLE>hopefully very minutely, im going to install mine today as well...
Old Apr 19, 2007 | 08:35 AM
stemiched's Avatar
from what i have read, i beleave some people just drilled a hole in there cross member to put the bottom support
Old Apr 19, 2007 | 10:32 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">from what i have read, i beleave some people just drilled a hole in there cross member to put the bottom support</TD></TR></TABLE>
You have to cut some out, drilling holes won't allow it to sit low enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">check out RCautoworks half size with slim fan 125 shipped to your door...awesome stuff i just got mine yesterday, seriously like one of the best HT buys for me </TD></TR></TABLE>
Thank you, $70 shipped for just the radiator.
Old Apr 19, 2007 | 12:27 PM
89efDUSTY's Avatar
Default Re: (RCautoworks)
i think i may be able to get away with it because i have the SIR hood but ill find out
Old Apr 22, 2007 | 10:58 AM
stemiched's Avatar
thanks guys for your help, i just installed the eg rad today.
just leaned it
JDMCivic95EG
Apr 28, 2014 08:29 PM
Arch-Angel
Aug 28, 2007 02:29 PM
ideal95
Jul 22, 2007 04:31 PM
DirtyBirdJR
May 3, 2005 07:55 AM
XzzYzzX
Apr 23, 2005 08:42 AM
