hf questions
Old Apr 18, 2007 | 05:49 PM
SFlCrx's Avatar
Default hf questions
well i got a few questions about the hf. i just picked one up and had some spare parts so maybe i'll make it a little more peppy.
i want to throw on my dx head and an si intake manifold, computer and tranny can the hf block handle that? revs to 6500? do i have to rig the dizzy to the head?and do i need any thing else for this to work? new to the hf
Old Apr 18, 2007 | 05:58 PM
gp70hs's Avatar
Default Re: hf questions (SFlCrx)
I believe you can do what you are proposing. If you change the ecu, as well as the intake, you should be Ok. I think the dizzy is the same.
Old Apr 18, 2007 | 06:02 PM
SFlCrx's Avatar
Default Re: hf questions (gp70hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gp70hs &raquo;</TD></TR><TR><TD CLASS="quote">I believe you can do what you are proposing. If you change the ecu, as well as the intake, you should be Ok. I think the dizzy is the same.</TD></TR></TABLE>
so the hf dizzy should fit in the dx head without a hack job? cause i know the mpfi dizzys are different then the dpfi dizzys.
Old Apr 18, 2007 | 07:56 PM
SFlCrx's Avatar
any one else?
Old Apr 18, 2007 | 11:03 PM
2slow4stock's Avatar
I believe you have to change the pistons also... Since the hf is orginaly a 8 valve (1 intake and 1 exhaust in each cylinder.) and the dx, si are 16 valve. Correct me if i'm wrong, but i think the other valves are going to interfer (the extra 8).
Old Apr 19, 2007 | 08:04 AM
SFlCrx's Avatar
thanks but i putting in a sohc zc from hmotors and a computer
Old Apr 19, 2007 | 04:05 PM
SFlCrx's Avatar
do i have to use integra axles/half shafts or change my hubs? is there anything i must change or is it a direct swap?
Old Apr 20, 2007 | 08:37 AM
SFlCrx's Avatar
bump
Old Apr 20, 2007 | 04:04 PM
SFlCrx's Avatar
anybody? jdm sohc zc and zc tranny into an 88 hf direct drop in?
Old Apr 21, 2007 | 12:18 PM
4g hatch's Avatar
if you are looking for a little more pep just change the intake,exaust manifold and computer. that transmisson really sucks for performance. the zc will work but i think you have to use the halfshaft from a 86-89 integra and, the axles from a 90-93 integra. you will have to change the hubs to dx hubs. hatchback or sedan will work
Old Apr 21, 2007 | 01:41 PM
SFlCrx's Avatar
thanks
liquidoblivion
13
May 19, 2011 12:07 PM
SFlCrx
May 23, 2007 09:05 AM
classic69
Dec 17, 2005 05:21 AM
iwouldHITit
12
Dec 30, 2002 07:40 PM
bluebullet
10
Jun 16, 2002 06:58 PM
