Any issues fitting 15X7 with a 38 offset?
Old Apr 18, 2007 | 05:41 PM
CWBETB's Avatar
Default Any issues fitting 15X7 with a 38 offset?
Im looking to buy some wheels that are 15X7 with a 38 offset wrapped in 205/50 tires, any issue with a 90 Honda Civic hatch with no rolled fenders? Thanks!
Old Apr 18, 2007 | 05:45 PM
r.wright's Avatar
Default Re: Any issues fitting 15X7 with a 38 offset? (CWBETB)
w/ the right drop u will be good
Old Apr 18, 2007 | 06:16 PM
CWBETB's Avatar
Default Re: Any issues fitting 15X7 with a 38 offset? (mr. R*L*X)
Thank you sir, not slammed here
Old Apr 19, 2007 | 07:06 AM
nsxtasy's Avatar
H-T Order of Merit
If they're for street use, I wouldn't get that size for a '90 Civic. The tires are too large. The best matching 15" tire size for your car is 195/50-15. And 195/50-15 will look too stretched on a 15x7 wheel. Stick with 195/50-15 and 15x6 (or no wider than 15x6.5).
The only exception (aside from track use) is if you want to use the Falken Azenis RT-615, which doesn't come in 195/50 so you're stuck with the larger 205/50 size.
Old Apr 19, 2007 | 12:30 PM
r.wright's Avatar
Default Re: Any issues fitting 15X7 with a 38 offset? (nsxtasy)
oops..i stand corrected. i didnt see that he said 90 civic.
Old Apr 19, 2007 | 04:00 PM
CWBETB's Avatar
Hmm so you think I may have a problem? I had 205 45/16"s before and had no problems but that was on a 40 offset.
Or are you just saying you dont prefer the look? Thanks
Old Apr 19, 2007 | 04:09 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB &raquo;</TD></TR><TR><TD CLASS="quote">Hmm so you think I may have a problem? I had 205 45/16"s before and had no problems but that was on a 40 offset.
</TD></TR></TABLE>actually what he is saying that 195/50 is the correct size. my bad for tellin you 205 was . i didnt read enough into it....anyway..if you have skinny or oversize tires then your rpm's will be screwed up a little.
if you see 65 on yer speedometer you will only probably be goin 63.
Old Apr 19, 2007 | 04:57 PM
CWBETB's Avatar
Right Im not to concerned about that but I do see his point, how about the rubbing thats my main concern
Old Apr 20, 2007 | 05:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB &raquo;</TD></TR><TR><TD CLASS="quote">Right Im not to concerned about that but I do see his point, how about the rubbing thats my main concern </TD></TR></TABLE>
To be sure you will avoid rubbing, stick with tires whose outer diameter is the same as the stock tires on your car. With 15" wheels, that's 195/50-15.
Old Apr 20, 2007 | 04:28 PM
CWBETB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks
SE71N
Jul 21, 2010 09:54 PM
EM1 Resto
May 11, 2010 03:52 PM
84subaruDL
Nov 3, 2006 02:10 PM
sumyungguy
Dec 14, 2005 02:28 PM
jimmhatch
12
Nov 21, 2004 01:41 AM
