backfire
Old Apr 18, 2007 | 03:22 PM
jit01's Avatar
Default backfire
Hi I have a 1995 del sol vtec and sometimes when I am at like let say 4000rpm or higher and I let off the gas it backfires I can hear crackles coming from the exhaust nothing loud tho. The only mods I have are mugen twin loop exhaust (catback) aem short ram intake, aem pulleys. It has a b16a3 motor and I use 92 octane gas.
ps: The car runs fine I am just curious what would cause this. The motor only has 124k on it.
Old Apr 18, 2007 | 03:26 PM
Padawan's Avatar
Darth ModerVader
Default Re: backfire (jit01)
Back-firing is generally caused by an overly-rich condition, where raw fuel in the exhaust ignites due to heat.
Old Apr 18, 2007 | 03:28 PM
jit01's Avatar
Default Re: backfire (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Back-firing is generally caused by an overly-rich condition, where raw fuel in the exhaust ignites due to heat. </TD></TR></TABLE>
So my car is running rich ? How do I fix this ?
Old Apr 18, 2007 | 03:45 PM
leeminho86's Avatar
I was backfiring a lot and I was told to check the valve lash and the distributor cap...my distributor cap is cracked and missing a bolt, have yet to replace it though.
Old Apr 18, 2007 | 03:47 PM
jit01's Avatar
Default Re: backfire (leeminho86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leeminho86 &raquo;</TD></TR><TR><TD CLASS="quote">I was backfiring a lot and I was told to check the valve lash and the distributor cap...my distributor cap is cracked and missing a bolt, have yet to replace it though. </TD></TR></TABLE>
o ok I guess I will take it to a mechanic when I have time
Old Apr 18, 2007 | 03:48 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">So my car is running rich ?</TD></TR></TABLE>
It's possible. Are you throwing any codes? Is the car up to date on scheduled maintenance?
Old Apr 18, 2007 | 03:59 PM
jit01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It's possible. Are you throwing any codes? Is the car up to date on scheduled maintenance? </TD></TR></TABLE>
I am getting no cels and I just bought the car from happy honda (honda dealership) in jan so I had it for like almost 4 months. I also don't remember if it was doing this before or not lol.. it only back fires some times I was thinking maybe its because I have an exhaust.
Old Apr 18, 2007 | 05:07 PM
1d10t's Avatar
do you have a catalytic convertor? b/c it happens during decel, makes me think the cats clogged or you have carbon build up on the injector causing it to leak.
Old Apr 18, 2007 | 05:26 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
my civic was stock motor stock ecu just intake header no cat and exhaust. 00 si it usto pop fire. the motor was never touched ! stock dizzy settings everything stock ! and it would pop fire. i dont think it was running rich.
Phr33l
Mar 14, 2012 02:30 PM
mkinpwrat12g's
Aug 18, 2005 07:26 AM
ItalynStylion
Feb 19, 2005 10:57 AM
BremertonDA
Oct 10, 2004 12:30 PM
equinox
May 27, 2004 10:11 PM
