Running fan after turning the car off
Old Apr 18, 2007 | 03:17 PM
Nate Graves's Avatar
Default Running fan after turning the car off
okay, I literally just got home after buying a '93 10th Anniversary Edition (I read online it uses the LX trim and the main addition is ABS), and like I mentioned in the title, there's a fan under the hood, near the front, that continues to run after I turn the engine off.
I didn't get an owner's manual or anything, so I dunno if it's supposed to be cooling the engine off or what. I really don't know that much...but somehow this strikes me as not supposed to be happening.
I can't figure out how to make it stop (it's been running about 20 min.), so I figure I'd come to you guys because...I don't know what else to do!
Thanks, in advance. I'll be watching this thread, but if you want to get a hold of me quickly, my AIM name is JuiceboxVillan and my cell is 574-210-6870.
Old Apr 18, 2007 | 03:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Running fan after turning the car off (Nate Graves)
It is normal for the fan to run for a little bit after turning the car, if it is very hot outside or you drove the car a little hard. On my 5th generation Accord, I estimate if it runs; it runs about 5 - 10 minutes to cool down the engine.
Running 20 minutes or more, I would check the coolant level in the radiator (after it cooled down, of course), and the reservoir. If coolant levels are okay, and it keeps running too long or don't stop, you may need to replace the radiator fan timer, which I believe is located under the driver side dash for your model year.
Old Apr 18, 2007 | 04:33 PM
chibiko's Avatar
Default Re: Running fan after turning the car off (tech8)
Maybe when this happens your radiator will die soon. This happened on my Accord 97.
Bruce Banner's Avatar
ditto, it's pretty normal, unless it runs for a long *** time
Old Apr 18, 2007 | 04:36 PM
high_revs's Avatar
normal.....
Old Apr 18, 2007 | 04:40 PM
Default Re: Running fan after turning the car off (chibiko)
hah! It better not, I just put a new one in today.
Old Apr 18, 2007 | 04:43 PM
5G_Vtec's Avatar
It's normal to do that. Mine even does it. It's just cooling. Don't worry about it unless it runs for a longgggg time.
Yeret
Sep 12, 2014 04:46 AM
kornerk12
Apr 1, 2010 11:00 PM
hillsidedrill
Apr 26, 2007 09:49 AM
cademan
Jul 23, 2006 03:40 AM
LB CRX
Nov 22, 2002 06:53 AM
