stripping my car
Old Apr 18, 2007 | 02:34 PM
nicko360's Avatar
* B A N N E D *
Default stripping my car
I am going to paint my car on friday, so i started taking off the trim etc. and have a few questions.
I took all of the door seals off, are those hard to get back on?
how do you take the drivers and passengers windows off?
ill probably have some more questions later
thanks
Old Apr 18, 2007 | 02:42 PM
97Ej6mike's Avatar
Taking the windows off? You dont need to do that for painting, thats what paint tape and sheets of plastic are for
Old Apr 19, 2007 | 12:23 PM
nicko360's Avatar
* B A N N E D *
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Taking the windows off? You dont need to do that for painting, thats what paint tape and sheets of plastic are for</TD></TR></TABLE>
i pulled that seal off that keeps the windows on track though, so now im kinda fucked cause I need to get the seal between thw window and the sides of the door
Old Apr 19, 2007 | 12:32 PM
WihaSi's Avatar
Default Re: (nicko360)
What seal are you talking about? A "seal that keeps the windows on track"? A guide channel? Be more descriptive and I may be able to help
Edit: Maybe the run channels?
Old Apr 19, 2007 | 12:37 PM
quackattack's Avatar
Default Re: (WihaSi)
i think he's talking about the plastic on the outside
Old Apr 19, 2007 | 12:42 PM
WihaSi's Avatar
Default Re: (quackattack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quackattack &raquo;</TD></TR><TR><TD CLASS="quote">i think he's talking about the plastic on the outside</TD></TR></TABLE>
How would that put the window off track? The only thing I can think of that keeps the window "on track" would be the run channel (outlines the inner door frame), guide channel (inside door shell, keeps window on track).
Old Apr 19, 2007 | 12:46 PM
turbociviccoupe's Avatar
bad idea to use plastic...when you pull the plastic off the paint will flake off the plastc and stick to the car. go with the blue painters paper.
Old Apr 19, 2007 | 12:53 PM
WihaSi's Avatar
In any case the windows should be fairly easy to take out. There should be 2, 10mm bolts through the window (where the window is seated in the regulator). Remove those 2 bolts (don't drop them in the door) then slide the window out slowly. If there are no bolts, then there may be some sort of clip holding the window in the regulator.
Old Apr 20, 2007 | 01:52 PM
nicko360's Avatar
* B A N N E D *
its the plastic lining that goes along the sides of the metal, where the edge of the window would be touching the part where the door hinge is, and the part close to the latch
if its still confusing I can take pictures
but, ill try to get the windows out, will i need to take the plastic lining off the door panels, and if so, should I get a new seal to put back on?
Rover2cool
10
Sep 28, 2011 09:09 PM
czirr321
Oct 26, 2009 12:15 PM
dabiddan
Aug 2, 2005 01:43 PM
B18CYAAA
Jul 13, 2005 11:51 AM
jaM3s Bond
Nov 21, 2003 11:46 AM
