ECU connectors contacts part number needed
Old Apr 18, 2007 | 02:28 PM
pdman's Avatar
Default ECU connectors contacts part number needed Tyco Amp
I am looking for part numbers and/or a siupplier for the contacts that are used in a 95 Integra ECU connectors.
The car was flooded last year and salt water was also mixed in.
The car stopped running last week and wouldn't start.
I traced it back to the ECU and found many corroded contacts in the connectors.
I opened up the ECU and there was much corrosion and oxidation inside as well.
I have another ECU on the way. However I am positive that many of the connector contacts will need to be replace.
There are 2 sizes . I have found out that the connectors and contacts are made by Tyco-Amp.
However I cannot find out part numbers for the contacts.
I called a few places but they were reluctant to divulge the part numbers and would only sell in super large quantities.
Does anyone know the part numbers for these contacts and where I can get them.
I am sure once I have the PN's I could get them from many of the major electronic parts distributors.
My other option is to go to the junkyard, cut off the 3 connectors from the harness, with ~ 6 inches of wire and then solder splice, heatshrink each wire connection.
Any help is greatly appreciated.
Thanks
Old Apr 18, 2007 | 02:54 PM
myfirstdc2's Avatar
Default Re: ECU connectors contacts part number needed Tyco Amp (pdman)
ls or gsr? i have a spare ls harness that i can cut off the ecu harness for u. i use this harness for spare pins to rebuild my existing harness. 40 bucks for the 3 ecu harness plus shipping if u want it. i will cut back about 10 inches or so for u. let me know
Old Apr 18, 2007 | 03:17 PM
pdman's Avatar
Default Re: ECU connectors contacts part number needed Tyco Amp (myfirstdc2)
Thanks for the response.
I think it's an ls but not sure, it's my Son's car.
As I stated, I can go to the junkyard and get the connectors and leave ~ 6 inches of wire.
However, I would still like to find the correct contacts for the ECU connectors.
I have 30 years in electronics and have used so many different types of connectors but this is the first time that I cannot find OEM part numbers for contacts or connectors. It's not like these are limited items. They are used iby many auto manufacturers, not just Honda.
Again thanks for the offer but I will continue looking for the oem PNs
rutchiesan15
Jan 10, 2013 12:39 AM
_HANS
Jun 13, 2004 03:33 PM
RoAnSa
Jun 20, 2003 09:37 AM
sailor
Apr 5, 2003 12:30 PM
