where is my ecu?
Old Apr 18, 2007 | 11:09 AM
q8delsol's Avatar
Default where is my ecu?
hii
i have read alot about ecu`s and i want try to chipping my ecu but when im searching in my car i never see my ecu?
i have a 93 del sol i know the ecu under the steering wheel but where it`s exactly? right left bihand? if i can see a pictur thats will helpful.
thanks
Old Apr 18, 2007 | 11:14 AM
hatchling37's Avatar
Default Re: where is my ecu? (q8delsol)
Right side. Remove the interior screws (plastic fastener, whatever) and it should be right there.
CEL thread <-- Look there
97civicdx's Avatar
Isnt it right next to the passenger's right foot like all Civic's and teg's? If you have never chipped an ECU, have it done professionally because if you accidentally solder something the wrong way your ecu might get messed up. If you have a spare one to use as you work, then go for it.
Old Apr 18, 2007 | 11:22 AM
q8delsol's Avatar
Default Re: where is my ecu? (97civicdx)
ohh,im so stupid all the time i have searching in other side
and yes i have 2 ecu`s p30 and the stock one i dont know the code i`ll see it tommorow
yes i never chipped one but i know how to use solder i`ll try
thanks
Old Apr 18, 2007 | 11:58 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol &raquo;</TD></TR><TR><TD CLASS="quote">ohh,im so stupid all the time i have searching in other side
thanks</TD></TR></TABLE>
What the hell is that abortion of wires???
Old Apr 18, 2007 | 12:10 PM
97civicdx's Avatar
Was your car a theft recovery? Wiring shouldnt look like that. Good luck to you. You will need to buy the socket then desolder the one on the ecu etc etc. Dont rush either.
P-30s are pretty expensive.
I hope you arent driving that car around with that busgetti hanging around, hehe
Old Apr 18, 2007 | 12:20 PM
q8delsol's Avatar
most of the wires in the pic for remote control (lock-unlock)
i know i need to reset the wires
the p30 come with my new engine b16a so still dont use the engine and the p30 i want learn about tuning on my ecu then i`ll swap the engine and ecu but after i doing right on tuning
Old Apr 18, 2007 | 12:27 PM
97civicdx's Avatar
tuning all depends on mods: injectors, cams, cam gears, etc. A p-30 is basically a p-28 with a knock sensor.
Old Apr 18, 2007 | 12:50 PM
q8delsol's Avatar
my d16a with intak sys. and dc headers but nothing inside engine
i hop i can doing every thing right
Old Apr 18, 2007 | 01:40 PM
amej8's Avatar
You want to chip your ECU with I/H/E?
Old Apr 19, 2007 | 03:36 AM
q8delsol's Avatar
Default Re: (amej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 &raquo;</TD></TR><TR><TD CLASS="quote">You want to chip your ECU with I/H/E?
what mean I/H/E??
but i have the chipping kit !
Old Apr 19, 2007 | 05:21 AM
dirtyafrican's Avatar
Default Re: (q8delsol)
intake header exhuast
Old Apr 19, 2007 | 05:34 AM
q8delsol's Avatar
Default Re: (dirtyafrican)
oh ic. i dont use the ecu just for I/H/E!
i have another engine b20\b16 so what i want to do training on how to tuning ecu on my old ecu. when i`ll have experience on it i will change all the engine and ecu
Old Apr 19, 2007 | 06:27 AM
q8delsol's Avatar
this what i have p29
i will open it and see what inside
Old Apr 19, 2007 | 08:09 AM
REAL EK9's Avatar
I rock a p70 ECU.
Old Apr 19, 2007 | 08:49 AM
Wharbone's Avatar
With your mods, a chipped ECU will probably make your car run shitty and you will get worse gas mileage.
Old Apr 19, 2007 | 09:31 AM
CRX T-Si's Avatar
Default Re: (Wharbone)
Your better off on saving the money until you get something like at least a cam or something internal for you engine.
What your doing is like tiping a flat chested girl at the titti bar, **** if you are gonna spend the money you better make it your while and tip the big titti girl that you will enjoy more.
Old Apr 19, 2007 | 11:08 AM
q8delsol's Avatar
Default Re: (CRX T-Si)
ok what im trying to say is i have no idea what ecu`s doing
and now i want to learn to join inside tuning world like step by step and then i will buy camshafts fuel inject...etc
reyrey2006
Sep 21, 2008 11:19 AM
senn1n103
Feb 18, 2006 01:01 PM
95integra_gsr
Dec 18, 2001 03:18 PM
