Integra RS w/ B17 YS1 Quaife LSD
***********pictures are down below*************
Will post pictures of suspension, new exhaust and such later this week....
1990 Integra RS Clean Title Chassis - White
-Complete OBD-1 93 GSR wiring harness conversion w/ P-81 ecu (93 GSR...)
-93 GSR B17A
-93 GSR YS1 W/Quaife LSD
-Koni race valved and shortened SPSS3's with GC sleeves, eibach springs
-Suspension Technique swaybars front and rear
-GSR black interior MINUS door panels
- I will find door panels before sale if buyer absolutely needs them.
-DC 421 Header (I know, crappy) and 2.5" test pipe that exits under/behind driver
-Brand new SMOG LEGAL custom exhaust is being built this week.
-Extra Front bumper with custom detachable splitter
-3 Rota Slips Black 16" great condition, 1 with a crack on the bead, 1 black steelie
-I will replace the bent slipstream when a sale has been arranged.
-Custom modified to fit Civic Skunk2 adjustable upper control arms
The car has been been converted to ALL GSR drive train and interior including dash and seats. There is no carpet, or door panels. There is no heater/core, A/C or blower motor. Under the dash is only the wiring harness and the fuse box from under the hood. The car has a clean wire tuck in the engine bay (battery relocated to the rear) with a Nearly Unmodified stock harness. (only head lights) This really should only be a track car, but it is currently registered, and can be smogged no problem, so its ideal because you can drive it to the track... Engine/Gear Box are very strong.
PM with Questions. MOTIVATED SELLER
Modified by deviate at 3:45 PM 4/23/2007
Modified by deviate at 3:46 PM 4/23/2007
Modified by deviate at 3:53 PM 4/23/2007
-93 GSR B17A
Gauge cluster from actual donor car of B17/YS1
GSR Interior
Interior shot showing removed A/C and heater boxes and climate control, carpet ect.
Left side no dents
Tow hook welded to bumper beam with unmodified front bumper cover.
Dent on hood and top of hood painted semi gloss black.
Dent / Crease on passenger side. Only real dent on car, NO RUST.
Paint imperfections on rear bumper cover.
ICEMAN INTAKE WILL NOT BE INCLUDED WITH SALE. Stock GSR air box is included. Shows battery has been moved, as well as fusebox and misc. wires.
B17A1 stamp & YS1 sticker. Very close ratio gearbox. (205/40/16 = 4600rpm @ 80)
Track only test pipe with straight through 2.5" muffler. Exhaust exits behind the drivers door, in front of tire.
Splitter easily attaches to a spare bumper cover that is not pictured.
Modified by deviate at 1:19 PM 4/23/2007
forgot to mention the 9lb flywheel, new clutch, new rotors, new wheel bearings, stainless brake lines, extended wheel studs and probably lots of other things.... ill keep editing as I remember things....
jackson racing supercharger for integra gsr, integra gsr black leather seats, turbo exhaust system 3
jeffchaisi
Sep 4, 2007 03:52 PM
