is this setup safe for turbo
Old Apr 18, 2007 | 07:59 AM
b20turbocivic's Avatar
Default Is this setup safe for turbo
i need to know if this setup is safe for turbo
b20z block
11:1 cr
stock rod with arp rod bolts
ge block gaurd
p 72 head
itr cams
skunk 2 pro seris mani
68mm tb
2.5 apexi ws exahust
full race turbo kit
400cc injectors
walbro 255 fuel pump
blox fpr
aem fuel rail
hondata s100
im wondering if i run this setup on 7 psi would it be safe its a daily driven car any help would be appreciated
Modified by b20turbocivic at 9:27 AM 4/18/2007
Old Apr 18, 2007 | 08:32 AM
willyboyK20's Avatar
Default Re: Is this setup safe for turbo (b20turbocivic)
rsx-s has the same compression ratio and people are turboing them left and right. Just tune the hell out it and it should be good.
If you want it to be a little safer throw a thicker headgasket on there to lower the comp ration.
Old Apr 18, 2007 | 08:37 AM
i have an ge head gasket on it right now i really dont wanna change anything because im about to go get it tuned in a couple weeks, how much boost can i use on this setup?
Old Apr 18, 2007 | 08:45 AM
boostedcivicsir's Avatar
Mr. Badwrench
i think you will run out of injector, before you make good power.
the weakness on the b20 is the sleeves remember. maybe step up to 550's, and be a little conservative especially with the static compression that high.
Old Apr 18, 2007 | 08:48 AM
93supercoupe's Avatar
Default Re: Is this setup safe for turbo (boostedcivicsir)
ur not going to make much power witha stock sleeve b20
440's will support a lil over 300whp i beleive.
Old Apr 18, 2007 | 09:46 AM
yea im not planning on pushing out alot of power right now what about dsm 450 would these be enough to push out about 300-350whp?
03EM2guy
24
Mar 27, 2011 07:32 AM
.CUBISH.
Dec 29, 2008 05:57 AM
bradykiller
May 27, 2005 09:48 AM
MugenNSX
Oct 4, 2002 03:50 AM
Beast53568
Aug 10, 2002 11:00 PM
