has any 1 tried to swap cable for hydro including peddal asembly
Old Apr 18, 2007 | 07:56 AM
civicsi_guy's Avatar
Default has any 1 tried to swap cable for hydro including peddal asembly
tried to search but only the conversion kits come up. my question is has any 1 swapped peddals and clutch master to make their ef fully hydro clutch if so can i get a parts list, any help will be apreciated thanks.
Old Apr 18, 2007 | 08:00 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: has any 1 tried to swap cable for hydro including peddal asembly (civicsi_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsi_guy &raquo;</TD></TR><TR><TD CLASS="quote">tried to search but only the conversion kits come up. my question is has any 1 swapped peddals and clutch master to make their ef fully hydro clutch if so can i get a parts list, any help will be apreciated thanks.</TD></TR></TABLE>
Search the archives too, there's plenty of info in there for 'cable hydro'
https://honda-tech.com/zerothread?id=721037
Old Apr 18, 2007 | 08:01 AM
dr_latino999's Avatar
Default Re: has any 1 tried to swap cable for hydro including peddal asembly (wiZCo)
The hydro pedal set will work but you'll have to cut the firewall. If you can get creative with fabrication though you can make an OEM MC work or you can install a remote MC.
Convert
Feb 1, 2009 09:51 PM
ladyfriend
Aug 2, 2007 10:41 AM
88 yellow crx
Jun 7, 2007 10:44 AM
RyanA
Jan 30, 2007 07:19 AM
juevi (old)
Welding / Fabrication
Mar 15, 2006 09:08 AM
