Honda S2000 Honda S2000
a little noise coming from rear end on my '02...
Old Apr 18, 2007 | 07:50 AM
LVCURVS's Avatar
Default a little noise coming from rear end on my '02...
It's almost like a rubbing noise, not like tire rubbing but a muffled sound. It never started until a week or 2 after i put on my new wheels and tires. It only does it when i'm going slow and turning fairly tight and in reverse it does it a lil as well. I'm just wondering if it's normal with the larger tires (245-40-17) having more grip and strain the rear end a lil more or what. i'll be changing the fluid this weekend so maybe that'll help.
Thanks guys!!
oh, diff then that last question but does anybody else have a little engine stumbling problem occasionally when starting out from a stop? i get it sometimes, but it's rare.
Old Apr 18, 2007 | 09:01 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: a little noise coming from rear end on my '02... (LVCURVS)
if it isnt rubbing of the tires you think its your diff??
you said it started after replacing the rims/tires... put your stocks back on and see if you hear it...
are you lowered?
Old Apr 18, 2007 | 09:23 AM
LVCURVS's Avatar
Default Re: a little noise coming from rear end on my '02... (S@nt0s)
i'm thinking it's the diff. but would rather not assume and see what others think. Nope, it's not lowered, the only mod done to the car is wheels and tires. I'll try my stock wheels tonight. If it helps, i have around 51k on it.
Old Apr 18, 2007 | 11:29 AM
Francesco's Avatar
what new rims/tires did you go with? I doubt they rub on a stock suspension.
Old Apr 18, 2007 | 11:53 AM
LVCURVS's Avatar
Default Re: a little noise coming from rear end on my '02... (Francesco)
The only time they rub is on big bumps or if i push it and load the suspension real good. It's rubbing on the lip inside the fender well. That's the only place it's rubbing and i just have to roll the lip to fix that.
MMMGIRL
Aug 7, 2012 04:36 PM
r1lsr
Aug 10, 2008 08:04 PM
kalm_traveler
Honda S2000
Jan 7, 2008 12:19 PM
ekcivic9
Oct 15, 2005 01:49 PM
OneThirtyEight
Nov 25, 2001 08:35 PM
