Z10 Radius traction arms
Old May 28, 2002 | 02:36 PM
slooowDX's Avatar
Default Z10 Radius traction arms
does anyone have these? im considering buying them for my 92 hatch, but i dont feel like forking up $350 if its not going to get rid of my wheel hop. I kno that EF/DA's come stock with a radius arm style suspension on the front, and i've seen several of these cars launch, and they get little wheel hop if any.... so i'm wondering if this would be the same on an EG/EK w/ the Z10 bars? BTW im running 205/50/15 Falken Azenis w/ neuspeed race springs, launching on the street around 3000-3500 is about the best but i still get hop...TIA
Old May 28, 2002 | 02:52 PM
.nate's Avatar
Default Re: Z10 Radius traction arms (slooowDX)
Ive heard that they all but eliminate wheelhop, but does anyone know if its true that if you're boosted if it will hit your boost pipes?
Old May 28, 2002 | 02:55 PM
Finest's Avatar
Default Re: Z10 Radius traction arms (TheFLY)
The only thing I can think of getting in the way would probably be the downpipe. All your intercooler piping should be inside the front bumper.
And YES!...it does eliminate wheelhop. I'd rather shell out $300 now, then buy a few axles down the line. Plus, it just makes your car feel more stable when driving.
Old May 28, 2002 | 03:02 PM
-Gambit-'s Avatar
Default Re: Z10 Radius traction arms (Prelude_RCR)
i have them on my ek and it did eliminate pretty much all wheel hop, they will not harm anything on your car if its a daily. (same suspension travel, and turning radius) I dunno if it will interfer with turbo piping but here is an article on the istall, with pics of the under side of the car with the z10 arms on. http://www.overboost.com/story.asp?id=460
[Modified by gambit33, 12:04 AM 5/29/2002]
Old May 28, 2002 | 03:07 PM
slooowDX's Avatar
Default Re: Z10 Radius traction arms (gambit33)
thanks man...i broke my timing belt side mount from so much wheel hop...i stripped out the three bolts that hold the mount into the block Z10 arms will be my next purchase
Old May 28, 2002 | 04:12 PM
-Gambit-'s Avatar
no problem man, that is why we are all here, to help each other out.
Old May 28, 2002 | 04:53 PM
mgast's Avatar
i deffinatly noticed an improvement with them. if you pair them up with some motor mount inserst the launches feel great. i just got to launch mine on slicks the other day and it was amazing.
later
matt
Old May 29, 2002 | 06:05 AM
Jason kiDD's Avatar
Default Re: Z10 Radius traction arms (mgast)
Did you have any clearance issues since you are a hybrid?? I emailed them about h22/EGs but got no reply on whether or not they can be used with the lude engine?? Anyone else know??
Old May 29, 2002 | 06:59 AM
acura_typer's Avatar
Banned
Default Re: Z10 Radius traction arms (Jason kiDD)
Its probable they can't be used. I am sure they haven't tested that out themselves, they would rely on someone else's experience.
I would guess they don't, but I've never seen a civic with an H22...
Old May 29, 2002 | 07:18 AM
Jason kiDD's Avatar
Default Re: Z10 Radius traction arms (acura_typer)
Inquiring minds would like to know...
Old May 29, 2002 | 07:21 AM
Chugger's Avatar
i saw in a summit book that bbk makes them also looks the same and probably does the same thing for half the price thats just something to consider
lata
chris
Old May 29, 2002 | 09:32 AM
Zer0DazE's Avatar
Default Re: Z10 Radius traction arms (01VaS2K)
i dont see those on either the bbk or summit web site
what catalog do you have, because i havent seen them in any of those either
Old May 29, 2002 | 09:36 AM
Jason kiDD's Avatar
Default Re: Z10 Radius traction arms (Zer0DazE)
He is probably referring to the Comptech one.. But I heard that is sux a$$...
Old May 29, 2002 | 06:04 PM
mgast's Avatar
as far as them working with a h22 it depends how much farther towards the driver side the oil pan sits because there is only like an inch and a half of room between the pan and the rod. as far as the competion engeneering ones go you have to look at were the actual radius rods mount on the front bracket if the rods go straight back it makes them alot harder for daily drivers for what i have heard. i have driven mine for months every day with no problems.
later
matt
Old May 29, 2002 | 06:23 PM
shawnhayes's Avatar
I have them on my 1992 Honda Civic CX with GSR motor B18C1
Couple of points:
1. They really help wheel hop
2. The front suspension is much firmer with them
3. In combination with poly bushings, hitting bumps really HURTS (because ride is so firm)
4. Helped induce a tad oversteer to my car (I like it actually)
5. Z10 phone support stinks - it took nearly three weeks to get the arms, and when they got here, the 19mm bolts to hook up the front links were nowhere to be found - I had to go buy them unless I wanted to wait three weeks.
6. With forward preload (what Z10 recommends) when you fully unload the suspension (i.e. - jack it up in the air) there is some suspension "binding" i.e. the wheels "stick" in the fully extended position. Driving a few miles "unstuck" them for me, but this was awfully unsettling (I thought something had broken - loudest "pop" I ever want to hear from my suspension - EVER)
7. Did I say I really like them? Yes, I do.
8. Losing the front splashgaurd SUCKS - I cut mine and made it fit ANYWAY - I don't care if people run without them - this is my everyday driver, and driving in rain and puddles is a fact of life. This wasn't easy - nor is it pretty.
Shawn
Old Jun 1, 2002 | 10:14 AM
TheSwift1's Avatar
question: what happens to the tow hook?? u have to remove it don't u? what happens if for some reason u need to have ur car towed? do u have to get one of those front tow hooks?
Old Jun 1, 2002 | 10:29 AM
poison's Avatar
Default Re: Z10 Radius traction arms (TheSwift1)
ya, i'd also like to know about h22 civics with the z10 radius arms.
as for:
yes you have to remove the factory tow hooks, and will have to either not have 'em, or get after market ones (u know those ugly ones, but hey, they function, right?)
[Modified by poison, 12:29 PM 6/1/2002]
Old Jul 5, 2002 | 03:05 PM
AllMotorHB's Avatar
Anyone ever figure out if the radius bars fit with a h22 civic? and which motor mounts they used? Place Racing? HCP?
Old Jul 10, 2002 | 12:48 PM
JDMHondaLawnMower's Avatar
Default Re: Z10 Radius traction arms (AllMotorHB)
Will these fit on my ride?
Old Jul 10, 2002 | 01:05 PM
B18C-EJ1
Guest
Posts: n/a
This is why you need these....
Old Jul 10, 2002 | 02:11 PM
slooowDX's Avatar
Default Re: Z10 Radius traction arms (B18C-EJ1)
are those the mounts for the AC braket and tranny bracket? look nice, how much?
Old Jul 10, 2002 | 03:30 PM
B18C-EJ1
Guest
Posts: n/a
$109 for the pair shipped.
Old Jul 10, 2002 | 10:02 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Z10 Radius traction arms (C5_ALLMOTOR)
I think I will buy the damn bars!!..but NRG racing..how much for the bars again?
Old Jul 10, 2002 | 11:25 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Z10 Radius traction arms (Blue-Civic-Hybrid)
Brian, you got PM.
Old Jul 11, 2002 | 04:14 AM
primoEF's Avatar
those mounts don't do a thing, get the bars if I were you
