Lower control arm will not budge! What to do?? what to do?? Ball joint is on there like swimwear!
Old Apr 18, 2007 | 04:40 AM
crx18c1's Avatar
Default Lower control arm will not budge! What to do?? what to do?? Ball joint is on there like swimwear!
any suggestions on how to BREAK THIS DAMN THIS UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 18, 2007 | 04:51 AM
CRX Toad's Avatar
Default Re: Lower control arm will not budge! What to do?? what to do?? Ball joint is on there like swimwear
Can you please give more details on what is going on and what you would like to accomplish.
Old Apr 18, 2007 | 04:52 AM
dr_latino999's Avatar
Trying to remove the axle? Simple solution, don't disconnect the Ball joint at the LCA, treat the Knuckle and the LCA as one piece and disconnect all the components attached to the LCA.
Old Apr 18, 2007 | 07:43 AM
crx18c1's Avatar
Got it out you guy are great!
What im trying to go is replace the Trans...Im un bolting all the 17mm and then the Rear motor mount. Long Process! GEAZZ!!
Old Apr 18, 2007 | 08:53 AM
I am Professor Chaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Got it out you guy are great!
What im trying to go is replace the Trans...Im un bolting all the 17mm and then the Rear motor mount. Long Process! GEAZZ!!</TD></TR></TABLE>
You don't need to take the ball joints out I never go. I remove the upper control arm chassis mounts, and drop the whole arm. I hate braking the balljoints loose. It usually tears the boot.
Old Apr 18, 2007 | 08:57 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I am Professor Chaos &raquo;</TD></TR><TR><TD CLASS="quote">
You don't need to take the ball joints out I never go. I remove the upper control arm chassis mounts, and drop the whole arm. I hate braking the balljoints loose. It usually tears the boot. </TD></TR></TABLE>
how do you deal with the shock/spring getting in the way of removing the upper arm?
still seems like youre better off just learning how to remove the balljoint properly.
https://honda-tech.com/zerothread?id=1912773
unclematt
12
Jun 2, 2016 04:31 AM
pixelphoto
Suspension & Brakes
Nov 9, 2015 03:44 PM
MalcolmV8
Apr 5, 2011 09:01 AM
jojowasha
Jan 14, 2007 01:49 PM
DaChoZn1
Sep 18, 2005 03:34 PM
