b16 header torque sequence
I've searched archived and new content and google also. I need the torque sequence for installing a b16 header and the sequence for removing the exhaust manifold bolts. I think i read the torque is 23 ft/lbs, is that correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">yeah i more concernced with the torque, is 23 correct</TD></TR></TABLE>
Yes, 23 ft lbs. Start with the centre bolt and alternate as you work your way out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">are you serious. Just do german torque measure. good-n-tight</TD></TR></TABLE>
It isn't uncommon to read posts regarding people snapping off exhaust studs or experiencing exhaust leaks, so wanting to torque the bolts properly is perfectly reasonable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">It isn't uncommon to read posts regarding people snapping off exhaust studs or experiencing exhaust leaks, so wanting to torque the bolts properly is perfectly reasonable. </TD></TR></TABLE>
Not to mention the fact that there just possibly could be a reason the manufacturer has torque-specs.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
yeah thats pretty much my thoughts. I have had to easy out snapped bolts before, it sucks ***
