Factory Foglights?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Originally posted by jaylat93 on Jun/07/06
not hard just put the light behind the bumper look at wat will need to be cut in order for the fog to fit and double check everything, then cut wit small hand saw or dremel. be sure not to cut the mounting slots in the bottom corners of the bumpers... very, very easy!!!
GL it didnt take me but 25 min to do and i had no clue wen i started....
This is also from Team-Integra:
"Totally plug and play. You don't have to run any wiring through the firewall. It's all there. It's like this. Under the hood, near the left headlights, there is a blue-taped 1-pin connector. That connector runs from that point into the car (pre-wired) to another blue-taped 1-pin connector. The kit has two harnesses: The one in the front that runs from that 1-pin connector down to the fog lights and the interior harness
You install the kit under the hood/grille and you run the wiring harness there with the wire ties with clips. Then you go under the dash and connect the interior harness to the 1-pin connector on the far left of the underside of the dash. You run the wires there, mount 1 relay and run the wire to the switch. You then plug one 1-pin connector into the back of the light switch on the steering column, where there's a "blank" slot."
now the part that connects under the hood i found and its just plug and play... but there is also a gold plated u shaped thing with it... that would just be used to ground it to a bolt in the engine bay??
the part of where to hook everything up inside is where im confused. I know where the switch mounts and plugging that in is easy just not sure about where in the dash the other blue taped connecter is? or the "blank" slot behind the steering column...
Here is the thread it came from.
Hope that helps a little bit :S
