86-89 integ head on a sohc d-series block
Old May 28, 2002 | 02:13 PM
rioninja's Avatar
Default 86-89 integ head on a sohc d-series block
My friend just put a fist gen dohc integ head on a sohc block. Dont know how it will flow, but the ports are much larger than a stock sohc si head. He plans on turboing it. I'll see if i can post some pics.
Old May 28, 2002 | 04:29 PM
chasrex's Avatar
Default Re: 86-89 integ head on a sohc d-series block (RioNinja)
I hear that doing it is an ordeal. pic's are nice but directions on how to do it without going crazy would be even more greatly appreciated. My understanding is that it is not an easy swap.
Charles
Old May 28, 2002 | 04:52 PM
Jared's Avatar
So after all that hard work, all he has is a ZC.
Old May 28, 2002 | 04:57 PM
CRX_VTEC's Avatar
Default Re: 86-89 integ head on a sohc d-series block (Jared)
had this swap done over a year ago....and I remember a post like this in which I responded and all I got was falmes!!! I think you probably remember that Rioninja.
Anyways... Its really alot of machine work.. and not worth the hassle. Now that motor is running on its last leg... but heh.... we put it together with junk and leftover parts from various swaps...so that motor was practically free. And free labor since we did it ourselfs.
Old May 28, 2002 | 04:58 PM
MrTodd's Avatar
No, not even that. The teg motors will only pump out about 118 hp (88-89teg) stock, ZC stock is at least 130 hp. However, this setup will give you a significantly lowered compression ratio - If you're only putting on the head... MAYBE better for a turbo than a ZC?
Old May 28, 2002 | 06:32 PM
Mugen Dom's Avatar
Default Re: 86-89 integ head on a sohc d-series block (MrTodd)
he told me about it sunday rioninja that is and he said it went on fine....but the compression chambers on the d16a1 is farken huge so id drop the cr significantly but i dunno how this thing will hold up
Old May 28, 2002 | 07:53 PM
rioninja's Avatar
Default Re: 86-89 integ head on a sohc d-series block (CRX_VTEC)
what kind of machine work was involved? Everything dropped right on, all the bolt holes lined up and everything. The only problem he has right now is he needs to find the right length timing belt, which shouldnt be that hard a problem at all really.
remember this is gonna get turbod. The ports on the head and intake runners are huge compared to stock si ones, so that -should- help some. He's mainly just messing around with junkyard parts for fun, so please no "just buy a ZC" posts.
i'll try to get some pics of what he has mocked up so far.
Old Jun 1, 2002 | 07:55 PM
Smokinsax's Avatar
The Boot
That is so crazy...I would love to see some pics.
Old Jun 2, 2002 | 06:18 PM
W0oT's Avatar
Banned
lol i'd like to see too.... definately frankenstein... you should have him find a turbo and manifold from something in the yard too lots of stuff you can walk out w/ if they let you look around by yourselves.
hondacrxsiguy
16
Dec 5, 2008 06:08 PM
chaddman
25
Jul 15, 2006 10:36 AM
bjfisher
Jul 4, 2006 08:50 PM
EK45VTi
10
Jun 22, 2004 01:18 PM
staticrex
Dec 23, 2003 09:13 PM
