Check engine light???????
Hey guys last weekend we installed a new clutch, light weight flywheel and Quaife LSD into our 88 CRX. Ever since then when you shift for the 7th or 8th time as soon as I press in the clutch the engine light comes on. I checked to see if all the connections we plugged back in and I don't see anything disconnected. I'm quite confused.... Any help would be great.
Check the ecu code. Turn the key one to the second postition and pull your carpet back and read the ecu flashes. one long blink is a 10 and 1 blink is 1. SO for example if you get one long blink with a blink thats an 11.
Sorry to bring this back from the dead.... But I finally got around to messing with this car. I turned the key on and the light just continues to pulse off and and on with no break. Is this a code 01?
01 = bad o2 sensor. the bosch ones from your local auto parts store work. as long as its ONE WIRE bosch.... 4 wire(obd1+) are crap.
check your wiring... follow the o2 its on the manifold. if its not plugged in plug it in. if it is maybe swap? its just a few dollars to replace
ramz7887
Nov 13, 2007 03:07 PM
