Car is primed...worried about leaving it that way
Old May 28, 2002 | 01:48 PM
LoooseGSR's Avatar
Default Car is primed...worried about leaving it that way
Hey I'm wondering if it is safe to leave my car primered...it's black and I'm planning on painting it black...I just don't know when...so my question is should I leave it primered...or get some cans of black enamel to give it a protective coat?
Old May 28, 2002 | 02:40 PM
LoooseGSR's Avatar
Default Re: Car is primed...worried about leaving it that way (PSUCRX)
Please guys...I have to drive 2.5 hours tonight...am I ok?
Old May 28, 2002 | 02:43 PM
technine's Avatar
YOU'RE OK.
Old May 28, 2002 | 02:48 PM
LoooseGSR's Avatar
Default Re: Car is primed...worried about leaving it that way (technine)
Thanks...although I'm not it's humid here and I don't want a bunch of bugs to get stuck on my front bumper and then not come off...
Old May 28, 2002 | 02:54 PM
MilanoRex's Avatar
if theres any problems just sand, and re-primer.
Old May 28, 2002 | 03:03 PM
Malgerus's Avatar
Since primer does not seal against moisture, don't drive it in the rain!!!! If that's not a problem, then yes, you can drive it without worry. IMO.
Old May 28, 2002 | 03:52 PM
LoooseGSR's Avatar
Default Re: Car is primed...worried about leaving it that way (89_Y_49)
the primer I have is rust resistant...which I'm sure doesn't mean waterproof...but I'll hold until I get it painted...
Old May 28, 2002 | 06:02 PM
KiddieRydesCRX's Avatar
It depends on what type of primer you used. If it's laquer (which I would never use) It's not going to hold up in the rain. If it's a 2K 2 part primer, you'll be fine. To make it simple, if it came out of a spray can, it's garbage.
Old May 28, 2002 | 10:47 PM
LoooseGSR's Avatar
Default Re: Car is primed...worried about leaving it that way (KiddieRydesCRX)
ouch...that sucks...couldn't afford the good stuff...so I guess I'll have to get it painted pronto
Old May 28, 2002 | 10:49 PM
dustin's Avatar
cheap Primer is like a sponge for moisture!
Old May 28, 2002 | 10:52 PM
K_1's Avatar
K_1
its all good dude! jus leave it primered till u can afford the real deal...my car is primered white, and will be gettin a white paint job when i gets the money....but i heard that primer absorbs moisture, and may cause rust, but my cars been ok for now for about 3 months now, jus as long as u wet sanded the last layer of that primer off and leave it smooth...well, i dunno if that helps, but itll do fine till the mean times!... ....i guess
Old May 29, 2002 | 12:07 AM
LoooseGSR's Avatar
Default Re: Car is primed...worried about leaving it that way (SPL-EF9)
thanks guys appreciate the info
JDMBS!
Oct 16, 2009 08:20 AM
allsho
Mar 29, 2005 04:47 PM
cedete
Jan 21, 2005 04:27 PM
BlendedEJ8
Jun 1, 2003 06:56 PM
