ls/vtec swap, having problems, what engine harness and ecu to use
Old Apr 17, 2007 | 08:10 PM
Teaser's Avatar
Default ls/vtec swap, having problems, what engine harness and ecu to use
I have a 96 civic dx and swapped it with a ls/vtec engine. The block is from a 90 ls and the head is a 99 civic si. I used my original engine harness from my dx by splicing the wires to fit the connectors and a P28 ecu with a chip and conversion harness, but it runs weak.
It idles up and down by itself and runs like it's got a misfire.
Pretty much is as weak as my stock motor but with a mis. and bad idle.
What kinds of engine harness and ecu should and can i use, and is this also the answer to my problems listed above.
What should the ignition timing with a timing light be set at? I was told at zero degress, is this correct?
Thanks very much.
Old Apr 17, 2007 | 08:25 PM
fmrprojects's Avatar
Default Re: ls/vtec swap, having problems, what engine harness and ecu to use (Teaser)
dude if its a stock block with stock head and b16 cams its gonna be weak. dont expect it to make like 180hp. its probably has like 150
Old Apr 17, 2007 | 10:01 PM
slvrlude's Avatar
true dat....hook it up w/ a typr r block
Old Apr 18, 2007 | 12:09 AM
nabin's Avatar
Default Re: (slvrlude)
dude if it runs as weak as your stock d15 then you've got problems. something must be wrong with the wiring. try using a wiring harness from a gsr. im running a 2000 si motor with an obd1 dizzy, and ive got an obd1 gsr wiring harness on it right now, runs great. i think the only thing you wouldnt hook up is the knock sensor, no knock sensor on the ls block. Obviously your not obd1, but i believe its all the same idea.
not sure on the whole timing thing since its ls/vtec, not sure if somethings different, i just match the lines on my b16. good luck man, sorry these other guys dont wanna try and help you out.
Old Apr 18, 2007 | 12:29 AM
my_b-series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrlude &raquo;</TD></TR><TR><TD CLASS="quote">true dat....hook it up w/ a typr r block</TD></TR></TABLE>
why would you want hook it up with a type r block, thats a waste of money.
yea something is wrong if its as weak as your d15. you should be making more horse and torque than a si. you should switch out the pistons, change the wiring harness and ecu to a si or gsr w/e you can get your hands on. you also need a good tranny. sorry but i know nothing about that timing crap though. i run a si with itr parts and and lsv is obviously a bit faster than si.
tuningrookie
May 3, 2007 04:53 PM
B16A3Civic*Eg
May 5, 2006 08:26 PM
LS_DON4500
Jun 28, 2005 01:38 PM
sydag5
Oct 7, 2002 11:47 PM
sydag5
Oct 7, 2002 08:36 PM
