Window issue, I dont think its off the track
Old Apr 17, 2007 | 07:51 PM
mjsotelo91's Avatar
Default Window issue
Hey guys, on my 1994 Honda Civic DX my manual window <U>window</U>-**** dosent seem like it is catching against the other gear, it just spins around, the panel is off but i can't see the gears because the rest of the door is metal welded on, is there any way to get the handle to hit the other gear again....if this is what it means for a window to be off track then let me know......thanks in advance
PS...what would i do if the gears were stripped?
Modified by mjsotelo91 at 9:03 PM 4/17/2007
Modified by mjsotelo91 at 12:21 AM 4/18/2007
Old Apr 17, 2007 | 08:57 PM
hatchi's Avatar
Default Re: Window issue (mjsotelo91)
did you put on the window roller handle while the door panel is off?? check which side is stripped the regulator or the handles if either one is stripped you'll need to replace
Old Apr 18, 2007 | 11:45 AM
mjsotelo91's Avatar
Default Re: Window issue (hatchi)
no, it was like that when i bought it...not long ago...ok il try to see if i can tell
thanks
8YourV8
Dec 13, 2010 10:09 AM
smooz EK
11
Dec 5, 2006 12:08 PM
hott-nix
Apr 3, 2005 04:04 PM
EnKidu
Oct 10, 2004 06:43 PM
Senbonzakura
Mar 27, 2003 09:31 PM
