Guage lights inop!!!
i just finished swaping EVERYTHING from my crashed Si into my HF body and my guage lights and my climate control lights dont work, i have changed out the dimmer switch and played with the connector and i cant figure it out
also, i cant find where this connector goes and it may have something to do with my problem
you should have labled it when youunplugged it
what year do you have bc that looks like a plug on the cluster for 88-89
do you have 2 connectors in theback of your gauge cluster
actually it might be for your hazards
do your blinks work
thats wierd why its under your dash hmm...
(its late)
do your blinks work
(its late)
my blinkers, hazards work as well as all my idiot lights but the guage lights just dont illuminate, im thinking it might be the miltifunction switch
its a 90 hf with 91 si interior and motor
check your horn fuse. No BS. I bet you it's blown. That was the reason my wouldn't come on. Don't ask. I got that car from mickey mouse himself.
dont be a dick.... i was trying to help you.
well, now i know it isnt the fuse or a the switch itself.
its something you didnt plug in. so fix it yourself, *******.
BTW, you spelled GAUGE incorrectly.
I wish I honda-tech's search was a little better, because I could find you the exact thread where this came up once before, a long time ago.
the only one I could find was this one, and its only slightly related:
https://honda-tech.com/zerothread?id=1570227
Basically, you are missing a small box that sits right underneath your cluster, under the steering column. This box is what that harness plugs into. This box controls the cluster lights, and just about anything that is supposed to light up in the cabin if your parking lights or headlights are on.
I know this, because mine fried one day. I had to resolder the transistors inside. And magically, my lights worked again!
Mine had a weird code stamped on the side that said AK-22, or AK-27, something weird like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haroldthefly91crx »</TD></TR><TR><TD CLASS="quote">hope you know, my tail lights work fine</TD></TR></TABLE>
BAN BAN BAN!
8===D
BAN BAN BAN!
8===D
it is called the dash light brightness control unit. it is attached by plastic clip just to the right of the steering column. i actually got mine from a square 91 civc and it worked in my 91 crx. Dash lights viola!!!!!
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">dont be a dick.... i was trying to help you.
BTW, you spelled GAUGE incorrectly. </TD></TR></TABLE>
I was going to try to help, but if the OP is just gonna be snippy about it then i'll leave him to fend for himself. Have fun tracing wires skippy!
sorry for being an ***, it was a bad day when i responded and i read your message as being "smart ***"
again, i apologise
thanks for all the help, but i still cant find the problem
again, i apologise
you get a
for apologizing. that isnt common here on h-t.
good luck. i'm not sure what it is. last time i had gauge lights out was in the 90s.
it was a bad headlight switch and also a blown fuse. the fuses are labeled for taillights/gauge cluster.
for apologizing. that isnt common here on h-t. good luck. i'm not sure what it is. last time i had gauge lights out was in the 90s.
your hands look like mine, you need some lotion...
theres a little black box that has holes in it thats usually attatched to your steering column. sorry if thats been said, i didnt read much
philkehn
Nov 5, 2006 08:39 PM
nortel
Aug 25, 2004 06:50 AM
