Overheating!!!!!!!!:(
Old Apr 17, 2007 | 05:53 PM
nonhondaman's Avatar
Default Overheating!!!!!!!!:(
My girlfriend has a 1990 Honda Civic 1.5L and the temperature gauge reads that it is overheating. I've changed a few things that i thought it could be, but it's still overheating. I really don't know a lot about honda's, so if someone could help that would be a real big help. Thanks
Thanks everyone for the input, it helped a lot, the cooling system needed to bled.
Modified by nonhondaman at 9:01 AM 4/18/2007
Old Apr 17, 2007 | 06:03 PM
Minh826's Avatar
Default Re: Overheating!!!!!!!!:( (nonhondaman)
What did you replace?
Old Apr 17, 2007 | 06:13 PM
AzCRX's Avatar
Default Re: Overheating!!!!!!!!:( (Minh826)
Sounds basic but check your coolant levels. If it isnt full then there is your problem. Also check to make sure the fan is turning on when the car heats up. Also if the coolant level is full you should bleed the coolant system. If there is air in the coolant system the air bubble will be super heated and when it hits the thermostat it will cause the gauge to read hotter than the coolant is.
Old Apr 17, 2007 | 06:51 PM
Lucky-13's Avatar
Default Re: Overheating!!!!!!!!:( (AzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCRX &raquo;</TD></TR><TR><TD CLASS="quote">Sounds basic but check your coolant levels. If it isnt full then there is your problem. Also check to make sure the fan is turning on when the car heats up. Also if the coolant level is full you should bleed the coolant system. If there is air in the coolant system the air bubble will be super heated and when it hits the thermostat it will cause the gauge to read hotter than the coolant is.</TD></TR></TABLE>
Old Apr 17, 2007 | 06:57 PM
Crx Jimmy's Avatar
Default Re: Overheating!!!!!!!!:( (youvgotmail)
IF the thermostat has been replaced and it still overheats check to see if the fan is working properly. It could also just be a faulty gauge or sender, you would have to hook up a mechanical gauge to check though.
Old Apr 17, 2007 | 07:01 PM
91ed9's Avatar
rad could be clogged also but try Azcrx 's said firt
Old Apr 17, 2007 | 07:05 PM
Lucky-13's Avatar
Default Re: Overheating!!!!!!!!:( (91ed9)
if it ends up actually being the radiator, you can get a new one for like 60 bucks from rcautoworks. great deal.
Old Apr 17, 2007 | 07:26 PM
No2Pencil's Avatar
mabe because 1.5L's are sooo jdm no what az crx said
junior_tm
Mar 1, 2012 11:40 AM
PyeeK
Mar 17, 2006 11:55 PM
HatchedGTI
Feb 10, 2006 10:47 AM
-Darren-
Jun 14, 2005 09:46 AM
superstud
Mar 14, 2004 08:54 PM
