What HP did you max out your walboro and stock fuel lines at?
Old Apr 17, 2007 | 05:53 PM
OMG B16's Avatar
Default What HP did you max out your walboro and stock fuel lines at?
I'd like to see what kind of power people have made on stock fuel lines with 1000cc injectors and a walboro 255lhp in-tank pump.
Please include: Fuel Pressure, Injector Duty, Horsepower. Thanks.
Old Apr 17, 2007 | 06:50 PM
pheurton-skeurto's Avatar
im very interested in this as well...
Old Apr 17, 2007 | 07:13 PM
Joseph Davis's Avatar
Default Re: What HP did you max out your walboro and stock fuel lines at? (OMG B16)
Walbro 255Hp with bigger than stock power and ground wires run to them are good for right at 600. Don't trust stock lines past 500, less if '01+ car, somewhere in the mid to high 300's.
PS - Dual intank 255's with 1/2" feed line and stock return = poor man's A1000.
Old Apr 17, 2007 | 07:34 PM
yaaj1320's Avatar
Default Re: What HP did you max out your walboro and stock fuel lines at? (Joseph Davis)
i have seen 600whp BUT the people who said that they did started to lean out on top....my tuner told me that i could run a bigger power wire to my fuel pump to make it work more efficient...so i could run 550whp safer...
i made 525whp and 410wtq..im sure i could have made 25-50 more whp...still got 5-6psi left for my 3 bar map....
Old Apr 17, 2007 | 07:38 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Walbro 255Hp with bigger than stock power and ground wires run to them are good for right at 600. Don't trust stock lines past 500, less if '01+ car, somewhere in the mid to high 300's.
PS - Dual intank 255's with 1/2" feed line and stock return = poor man's A1000.</TD></TR></TABLE>
Good to know. I will upgrade my power and ground wires, my goal is 550-600hp.
Old Apr 17, 2007 | 08:00 PM
Yah, 10 to 12 gauge wire for both power and ground. Use the stock fuel pump wiring to actuate a relay, and DO NOT trust the chassis as a ground path as with the stock wiring; go directly to the block. Lastly, don't forget a fuse.
Seriously, you'll hear a difference in how the fuel pump sounds when you cycle the key to the on position. Stock wiring sucks.
Old Apr 17, 2007 | 08:11 PM
yaaj1320's Avatar
ok i have heard of this.....can somebody explain to me how to exactly do this...plz...SO WOULD i use a 10 or 12 gauge wire???
as far as the ground i would ground it to the block???or neg. battery??
Old Apr 17, 2007 | 09:10 PM
Default Re: What HP did you max out your walboro and stock fuel lines at? (yaaj1320)
I already explained it. It's two wires, bro, not remotely difficult.
The engine block is the common point of the vehicle's electrical system. Here:
http://innovatemotorsports.com...g.php
Old Apr 18, 2007 | 12:10 AM
jdizzle!
Guest
Posts: n/a
good info, in for more answers
Old Apr 18, 2007 | 03:24 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What HP did you max out your walboro and stock fuel lines at? (jdizzle!)
255, stock wires, stock feed to filter, -6 from filter to rail, to reg, to return. 540whp +- cant remember duty sorry it was approaching 80 though if i remember.
Old Apr 18, 2007 | 04:05 AM
red cx's Avatar
Default Re: What HP did you max out your walboro and stock fuel lines at? (boostedcivicsir)
good info. My buddy just made 600 on a 255 with different wiring and a relay
Old Apr 18, 2007 | 04:12 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: What HP did you max out your walboro and stock fuel lines at? (turbosmart)
The neg battery terminal will work just the same as the engine block if not better.
Old Apr 18, 2007 | 08:04 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Use the stock fuel pump wiring to actuate a relay,
The stock pump wire as in the wire going directly to the pump? Or the smaller wire at the main relay?
Thanks!
Old Apr 18, 2007 | 08:08 AM
HiProfile's Avatar
Default Re: What HP did you max out your walboro and stock fuel lines at? (White Smoke)
It comes down to resistance of the connection. 12awg is rated for 41amps (on average), which is a lot of power even for a possitive displacement fluid pump. 12ga is a bit large, but it doesn't really matter.
I'd rather ground right to the battery if you want the most out of it, since the block is still aluminum (more resistance than copper), and still has to travel 2-3ft through the chassis.
Old Apr 18, 2007 | 09:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">The neg battery terminal will work just the same as the engine block if not better.</TD></TR></TABLE>
It will work just the same if the connection between negative battery terminal and the block is perfect. It will never work better. The alternator is the chunk of metal bolted to the engine that creates more than 12.8 volts during engine operation, and it grounds through it's housing to the engine. On my drag car it creates 16 volts for various reasons, over driving fuel pump and coil being the primary two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">It comes down to resistance of the connection. 12awg is rated for 41amps (on average), which is a lot of power even for a possitive displacement fluid pump. 12ga is a bit large, but it doesn't really matter.</TD></TR></TABLE>
Yah, but all the extra surface area it has when crimped (and then ideally soldered) to a connector really pays off in longevity. A little overhead that doesn't cost more than pennies extra never hurt anything.
Old Apr 18, 2007 | 11:00 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">I already explained it. It's two wires, bro, not remotely difficult.
good lord who are you and what did you do with the real JDavis??
Old Apr 18, 2007 | 11:03 AM
Default Re: What HP did you max out your walboro and stock fuel lines at? (notoriousB)
There can be only one!
Old Apr 18, 2007 | 12:42 PM
nasteboyii's Avatar
1000rc injectors b16a stock sleeves, aem fuel rail fpr walbro 255hp pump
made 594 at 30psi
which was prob close to max fuel pressure under 80 percent duty cycle but close
dan
Old Apr 18, 2007 | 12:52 PM
SPOOLINmatt's Avatar
Default Re: What HP did you max out your walboro and stock fuel lines at? (nasteboyii)
255walbro and 1000cc on stock wires and hoses, 630, and the fuel never dropped off, stopped there.
Old Apr 19, 2007 | 08:21 AM
OMG B16's Avatar
I'll do a writeup for you guys when Kenny(Turbogixxer) comes over and wires this up for me.
Old Apr 19, 2007 | 08:23 AM
nexxxt's Avatar
Default Re: (OMG B16)
you could always run a 255 intank and another inline cole, i know fred HPC made over 700whp on that car and went 10.1 @ 149 be4 he sold it....
if anyone can actually manufacture a bracket for two intank pumps that would be great but i dont think anyone has done it yet..
Old Apr 19, 2007 | 10:28 AM
i my honda
Global Mod
Default Re: (nexxxt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexxxt &raquo;</TD></TR><TR><TD CLASS="quote">if anyone can actually manufacture a bracket for two intank pumps that would be great but i dont think anyone has done it yet..</TD></TR></TABLE>
It's not the bracket that's the problem. Its fitting them into the tank at the same time that is the issue.
Old Apr 19, 2007 | 10:46 AM
Default Re: (White Smoke)
you have to cut the entry point on the tank to be able to fit them, not worth it.
Old Apr 19, 2007 | 06:58 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexxxt &raquo;</TD></TR><TR><TD CLASS="quote">you could always run a 255 intank and another inline cole, i know fred HPC made over 700whp on that car and went 10.1 @ 149 be4 he sold it....
Im gonna see how the one in-tank does, if i have any issues up top, i'll add another pump in-line.
Old Apr 20, 2007 | 07:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexxxt &raquo;</TD></TR><TR><TD CLASS="quote">you could always run a 255 intank and another inline cole, i know fred HPC made over 700whp on that car and went 10.1 @ 149 be4 he sold it.</TD></TR></TABLE>
411 whp off of a 255HP, 10.3@144. Car would dip into the 9's but needs taller slicks.
700 whp and flat 10's is stupid, whatever you do don't pay attention to that guy.
