Accord keyfob programming
Old Apr 17, 2007 | 03:44 PM
atomstwins's Avatar
Default Accord keyfob programming
Can anyone give tme the steps to program the keyfobs? I have done it on a Maxima, but not an Accord. Are they similar? Thanks in advance.
Old Apr 17, 2007 | 03:46 PM
foist1's Avatar
Default Re: Accord keyfob programming (atomstwins)
year make model
Old Apr 17, 2007 | 05:36 PM
atomstwins's Avatar
Default Re: Accord keyfob programming (foist1)
98 LX
Old Apr 18, 2007 | 05:28 PM
atomstwins's Avatar
no help???
Old Apr 18, 2007 | 05:43 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
This was copied from service bulletin instructions for an Acura R/L; but, usually, procedures are the same across different models:
Notes: 1) Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all the transmitters once you’re in programming mode. The system accepts up to three transmitters.
2) To keep the system from exiting the programming mode, complete each step within 5 seconds of the previous step, and program the transmitters within 10 seconds of each other.
Steps:
1) Turn the ignition switch ON (ll)
2) Press the “LOCK” or “UNLOCK” button on one of the transmitters. (A non-programmed transmitter can be used for this step.)
3) Turn the ignition switch OFF (0).
4) Repeat steps 1, 2 and 3 two more times with the transmitter used in step 2.
5) Turn the ignition switch ON (ll).
6) Press the “LOCK” or “UNLOCK” button on the same transmitter. Check that the power door locks cycle to confirm that you are in the programming mode.
7) Press the “LOCK” or “UNLOCK” button on each transmitter. (You can program up to four transmitter per vehicle.) Check that the power door locks cycle after you push each transmitter button, confirming that the system has accepted the transmitter’s code.
Old Apr 18, 2007 | 05:55 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Found similar instructions on PDF for Hondas:
http://www.handa-accessories.c...g.pdf
Old Apr 20, 2007 | 02:33 AM
atomstwins's Avatar
Default Re: (tech8)
Thanks folks. I guess the car never had keyless and I need more than to just program the keyfobs I have. Know what other parts I need to add keyless to the car?
Sklute
Classic Hondas
10
Jul 14, 2014 05:58 PM
jessicamoore
Jun 19, 2014 08:07 AM
bluesguitarguy72
May 9, 2007 11:22 AM
1320performancefreak
Mar 7, 2006 10:48 AM
matt_in_sd
Jan 17, 2006 06:32 PM
