*** hondata launch control question ***
Old Apr 17, 2007 | 02:31 PM
BUCK_NASTY's Avatar
Default *** hondata launch control question ***
I have a del sol tuned with hondata s300... and after I had it tuned I was looking at the settings on my computer and the launch control was not tured on...I was just wondering if it was ok to just check the box to turn it on, set the rpm, and set it to the "always on" setting and set the maxspeed to like 2mph or something low like that, the reason im asking is because there is also options to adjust fuel and timming, but do I have to do that or can I just turn it to "always on" and set the rpm and speed to turn off??
also with the full throttle shift can I just turn that on and set the rpm, and set it to "always on"as well...or is there anything special that I would need to do, there is also a check box that says invert input on both the launch control and the full throttle shift do I just leave that unchecked??
Old Apr 17, 2007 | 03:08 PM
BUCK_NASTY's Avatar
bump
Old Apr 17, 2007 | 04:28 PM
TNRspeed's Avatar
Default Re: (BUCK_NASTY)
someone answer this guys question. I was looking into getting hondata s300 also.
Old Apr 17, 2007 | 07:20 PM
GetawayInMoscow's Avatar
Default Re: (TNRspeed)
yes all that is fine
Old Apr 19, 2007 | 09:59 AM
Spunkster's Avatar
Default Re: *** hondata launch control question *** (BUCK_NASTY)
Full throttle shift cannot be set to always on or you will always have a revlimit of whatever you set the full throttle shift to. You must set up the input you wish to use for that and run the wire to a clutch switch.
Old Apr 20, 2007 | 07:16 PM
BUCK_NASTY's Avatar
when I want to chang the rpm level...do I just plug my ecu in and download whats on my ecu to my comp. , then chang the rpm, then upload it back to the ecu?? Is this all I have to do?
Old Apr 20, 2007 | 07:20 PM
SkertySkerty's Avatar
hows about this i know you want to do it yourself but goto the guy who tuned it for you the first time and see what he says and tell him to teach you if you dont know how to already and do it if you dont have neone get the instructions out
Old Apr 20, 2007 | 07:28 PM
uneek360's Avatar
Default Re: (SkertySkerty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty &raquo;</TD></TR><TR><TD CLASS="quote"> tell him to teach you if you dont know how to already</TD></TR></TABLE>
I think he'z sayin to get someone that know.z what der doing to teach you so you won't go n Fck things up, then make a topic " I Fckd my ecu ".
I would take that and see how far it takes you. If you don't wanna take the advise then go right ahead, at the end of the day it's your car.
Modified by uneek360 at 12:49 AM 4/21/2007
Old Apr 20, 2007 | 08:29 PM
yoffer's Avatar
Banned
Bump
obnoxiousls
Engine Management and Tuning
Aug 30, 2008 07:44 PM
BUCK_NASTY
Apr 21, 2007 05:48 AM
BUCK_NASTY
Apr 20, 2007 07:42 PM
4o8itr
Nov 8, 2006 09:48 PM
B18PoweredCivic
Apr 2, 2003 03:15 PM
