1997 Acura 2.2CL Misfire
Old Apr 17, 2007 | 02:10 PM
abuesing's Avatar
Default 1997 Acura 2.2CL Misfire
My car has been misfiring off and on for the last couple of weeks, and I can't seem to fix the problem. I replaced the plugs, wires, distributor cap, and rotor. After I did that, the car ran for about 400 miles with no problems, and then started misfiring again. The code is P0302(# 2 cylinder misfire). It usually misses at steady rpm's. But not all the time. Is this an injector problem? Any suggestions?
Thanks!
Old May 10, 2011 | 04:29 PM
bmwizard's Avatar
Default Re: 1997 Acura 2.2CL Misfire
hi, please help i have exactly same problem.. keep investing money, please help if you know what the problem is.. bmwizard@rogers.com
Old Dec 11, 2011 | 11:02 AM
zocator's Avatar
it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression, i could tell you a whole lot more and spend all day typing out ways to figure this out, but instead ill just give you a link. this page should tell you everything you need to know
http://www.aa1car.com/library/misfire.htm
Old Dec 11, 2011 | 07:41 PM
Hairnandez's Avatar
welcome to a 7 month old reply to a 4 year old thread
azn_ignite
Jul 23, 2009 02:36 PM
superdat1
May 1, 2008 10:20 PM
Spoon-ITR-
Mar 1, 2007 06:08 PM
ThatRicerDaniel
Feb 3, 2003 10:53 AM
89JDMcrx
Sep 9, 2002 11:11 AM
