del sol seats
Old Apr 17, 2007 | 01:37 PM
projsectEF's Avatar
Default del sol seats
does anyone have del sol seats in their ef? I'm thinking about picking some up, but want some opinion first. does it fit well, and is it comfortable?
Old Apr 17, 2007 | 02:25 PM
89efDUSTY's Avatar
Default Re: del sol seats (projsectEF)
on my rex its fits well and is comfy...swap out the seat pans; please dont just drill holes because sheet metal doesnt hold well if you get in an accident. The heighth is ok it feels about the same as the SI seats... Make sure that when you put them in you shave the plastic piece on the side because the floor has grooves and it wont slide. Also tap some holes into the arm where it meets the seat pan, use the correct fastners...dang i should have done a write up on this because this question comes up like every month or so, and people just half *** it...but i know if i get in a crash i wont fly out the window...PM me if you need more info
Old Apr 17, 2007 | 02:49 PM
Slurp56's Avatar
I've got Del Sol seats in my CRX as well. Much better than the pleather covered CRX seats I had before.
What I did to make them fit was use a combination of the CRX and Del Sol seat rail. I didnt have to swap seat pans or anything like that. I used the seat rails (sliding section) from the CRX and used the seat brackets (everything above the sliding portion of the rails) from the Del Sol. No plastic shaving or anything,they work really well and sit low to the ground.
Old Apr 17, 2007 | 02:51 PM
slowman's Avatar
I took way too long
Default Re: del sol seats (Slurp56)
My friend had some del Slo seats in his EJ1, I hated them. Sat WAY too low. Iono bout them in an EF. I love my stock Si seats though
Old Apr 17, 2007 | 03:03 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 &raquo;</TD></TR><TR><TD CLASS="quote">I've got Del Sol seats in my CRX as well. Much better than the pleather covered CRX seats I had before.
What I did to make them fit was use a combination of the CRX and Del Sol seat rail. I didnt have to swap seat pans or anything like that. I used the seat rails (sliding section) from the CRX and used the seat brackets (everything above the sliding portion of the rails) from the Del Sol. No plastic shaving or anything,they work really well and sit low to the ground.</TD></TR></TABLE> probably way low, and how did you put the sliders into the del seat rails?
Old Apr 20, 2007 | 01:38 PM
Slurp56's Avatar
Default Re: del sol seats (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> probably way low</TD></TR></TABLE>
I assure you, it is not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> and how did you put the sliders into the del seat rails?</TD></TR></TABLE>
It's been so long I honestly cant remember. I either welded them or used bolts/nuts. Pretty sure I used bolts/nuts though.
Old Apr 20, 2007 | 01:49 PM
89efDUSTY's Avatar
It's been so long I honestly cant remember. I either welded them or used bolts/nuts. Pretty sure I used bolts/nuts though.</TD></TR></TABLE> bolts and nuts FTW some retard welded my seat pans to ek rails part of the reason why i had to swap pans
Old Apr 20, 2007 | 04:41 PM
c1_sleeper's Avatar
del sol seats in a sedan FTW
-bad pic tho
Old Apr 20, 2007 | 04:42 PM
barely4dr's Avatar
Default Re: del sol seats (c1_sleeper)
^^logged in under a friends name FTL ^^
Old Apr 20, 2007 | 04:49 PM
c1_sleeper's Avatar
Default Re: del sol seats (barely4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barely4dr &raquo;</TD></TR><TR><TD CLASS="quote">^^logged in under a friends name FTL ^^</TD></TR></TABLE> hahaha.. i just looked at my recent topics and i was like WTF.i didnt post here!!.. its cool
we made the brackets for that car.... it wasnt hard at all!!
Old Apr 20, 2007 | 04:53 PM
barely4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1_sleeper &raquo;</TD></TR><TR><TD CLASS="quote"> hahaha.. i just looked at my recent topics and i was like WTF.i didnt post here!!.. its cool
we made the brackets for that car.... it wasnt hard at all!!</TD></TR></TABLE>
nope. 2 ppl, mild gauge aluminium, and patience.
Old Apr 21, 2007 | 09:04 AM
crx_si-r's Avatar
y did u have to make some brackets? i had del sol seat in my crx and all i had to do was swap the orginal del sol seat pans and sliders for my stock crx pan and sliders i think i had to re-drill one of the holes to make it a little bit bigger but that was all the modificiation i needed.
Old Apr 21, 2007 | 09:35 AM
c1_sleeper's Avatar
Default Re: del sol seats (crx_si-r)
we did it w/o swapping the seat pans cuz he didnt have his original EF seats in there
hfcrx88
Nov 3, 2009 12:29 PM
wubanga
Apr 7, 2009 07:40 PM
nk2k2
10
Mar 4, 2006 03:30 PM
red_EF9Si
15
Aug 3, 2005 01:06 PM
messeduprex
Apr 9, 2005 05:39 PM
