royal purple synchromax in b16 cable trans also 10w30 question
Old Apr 17, 2007 | 12:06 PM
nexgen91's Avatar
Default royal purple synchromax in b16 cable trans also 10w30 question
i head its not ok to use full synthetic oil in your trans, but what about RP synchromax? Its the only "synchro" somthing MTF I can find, so I am wanting to try it. Would it be ok, as it has "synthetic, proprietary Synerlec additive technology"? Also is 10w30 ok for short term use, I plan on giving the car a little abuse with it in to see if its leaking, then change to RP if its not.
Also what one is the fill hole in the pic?
Modified by nexgen91 at 9:29 PM 4/17/2007
Old Apr 17, 2007 | 12:30 PM
nexgen91's Avatar
Default Re: royal purple synchromax in b16 cable trans also 10w30 question (nexgen91)
bump, need an answer quick
Old Apr 17, 2007 | 12:47 PM
IP RACING's Avatar
its the gold on that is right next to wher e axle meets the tranny. I believe its a 17mm
Old Apr 17, 2007 | 03:23 PM
danmdevries's Avatar
Default Re: royal purple synchromax in b16 cable trans also 10w30 question (IP RACING)
backside of the differential, 17mm gold bolt on the rear side of the axle.
Old Apr 17, 2007 | 08:16 PM
nexgen91's Avatar
Default Re: royal purple synchromax in b16 cable trans also 10w30 question (danmdevries)
so, its not either one of the ones Id take out with a 3/8 ratchet or allen wrench? anything about the RP synchromax??
Old Apr 17, 2007 | 08:47 PM
ian1006's Avatar
the gm synchro-mesh is the best i have ever used. no idea about the other stuff though sorry. also just pull the speed sensor up on top of the tranny its a lot easier to fill that way
Old Apr 17, 2007 | 11:43 PM
nexgen91's Avatar
Default Re: (ian1006)
im actually looking for the fill hole so I can see if the tranny has enough fluid in it. Im going to fill it through vent hole or vss hole.
Old Apr 18, 2007 | 06:04 AM
ChickenH's Avatar
I used that in my grinding ys1 for about 2 years. It helped a little. The lsd didnt wear out or anything. I eventually broke the blocking ring from 2 to 3 gear And shaved part of 3rd gear off . besides that nothing else looked worn in the trans. I had 20k miles of turbo b beating on it.
the fill hole is that gold colored plug your 3/8th ratchet head fits into. mine didnt look like that though it was a 17mm bolt head
Old Apr 18, 2007 | 07:18 AM
SOHCwarrior's Avatar
Default Re: (ChickenH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH &raquo;</TD></TR><TR><TD CLASS="quote">
the fill hole is that gold colored plug your 3/8th ratchet head fits into. mine didnt look like that though it was a 17mm bolt head</TD></TR></TABLE>
no, It's the 17mm just to the left of where the axle goes into the tranny in your pic.
Just go to your local GM dealership and get syncromesh, a lil expensive, but good ****.
Old Apr 18, 2007 | 12:07 PM
nexgen91's Avatar
Default Re: (SOHCwarrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCwarrior &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the info. im in germany, no gm dealers that i know of. im just going to use the royal purple stuff.
Old Apr 18, 2007 | 12:12 PM
black88si's Avatar
Default Re: (nexgen91)
My friends have told me that royal purple is great stuff.
Pennzoil synchromesh is the same thing as the GM synchromesh and is a lot cheaper.
Old Apr 18, 2007 | 01:48 PM
WWDTrackRacer's Avatar
New User
Default I fill through the VSS sender hole
Way easier to get gear oil in through there than at a right angle.
Old Apr 18, 2007 | 02:11 PM
gnar kill's Avatar
Default Re: I fill through the VSS sender hole (WWDTrackRacer)
don't know about the royal purple but the gm syncromesh greatly reduced my third gear grind from grinding every time to only grinding at high rpm shifts
Old Apr 18, 2007 | 02:42 PM
eL_cArLos's Avatar
Default Re: I fill through the VSS sender hole (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">don't know about the royal purple but the gm syncromesh greatly reduced my third gear grind from grinding every time to only grinding at high rpm shifts</TD></TR></TABLE>
Might have to try that...
Old Apr 19, 2007 | 10:38 AM
eL_cArLos's Avatar
Default Re: I fill through the VSS sender hole (eL_cArLos)
Can you run the Lucas stuff? anyone ever tried that or is it just for Auto trannies?
Old Apr 19, 2007 | 12:06 PM
Gearspeed-Performance's Avatar
Make sure that it is nothing close to gear oil or you will have a burned up transmission in no time ....We recommend OEM fluid only
If you have a grinding issue...fix it the right way...fluid might mask the problem but, its still there.
Old Apr 19, 2007 | 12:26 PM
CBURKE's Avatar
So only the Honda Gear oil? I was wondering about the RP also, but I know there is some type of additive that Honda uses in there fluid.
The RP stuff is not to hid anything but to help with the amount of friction. I don't think you are supposed to use 10/30w. It should be a even 30w or 40w MT oil. Witch I always thought it was called gear oil.
Old Apr 19, 2007 | 12:36 PM
Default Re: (CBURKE)
Honda MTF is close to a 10w30 motor oil
<U> Do not use gear oil</U>
Old Apr 19, 2007 | 02:28 PM
black88si's Avatar
Default Re: (GearSpeedEF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF is close to a 10w30 motor oil
<U> Do not use gear oil</U></TD></TR></TABLE>
I am sure you guys know transmissions WAY better than I.
But I only use Pennzoil Synchromesh in my car........
Why do you only reccomend Honda MTF?
Old Apr 19, 2007 | 05:26 PM
gator88's Avatar
Default Re: (black88si)
I run Redline MTL and love the buttery smooth shifts and no grinds. Perfect, "click" into gear and feels like abrand new tranny. If you can find that I would recomend it, unless u are dead set on royal purple. I dont want to help start a "what fluid" thread inside of yours, but you said u are in germany, so I didnt know what you had available and if you were picking lubes based on price and/or availability. Hope you understand my babbling
Old Apr 23, 2007 | 12:32 PM
New User
Default RP website
http://www.royalpurple.com/techa/tranxref.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Honda / Acura All Models SAE 10W30 / XPR 5W30</TD></TR></TABLE>
Old Apr 23, 2007 | 01:24 PM
CBURKE's Avatar
so you use the motor oil as the MT fuild
SAE 10W30
XPR 5W30
Old May 4, 2007 | 09:35 AM
New User
Default Put RP into my gearbox
I ran Honda MTF for one track day on my rebuilt tranny. I drained it out and replaced with RP 10W30 engine oil. I should be going to another track day in May. I'll let you folks know how it works out.
Old May 4, 2007 | 10:23 AM
IT GUY's Avatar
Default Re: Put RP into my gearbox (WWDTrackRacer)
try not to use the words "gear-oil" or "gear-lube" too much... Gear lube is very heavy viscosity, 75w90 alot of times. What goes in Honda transmissions is MTF. Motor oil is only supposed to be used in "emergencies" and for short term use.
we don't want a bunch of noobs turning their trannys into boat anchors
Old May 4, 2007 | 10:36 AM
abnaasefmb's Avatar
Default Re: Put RP into my gearbox (IT GUY)
don't use the royal purple stuff, i made that mistake once. stay with honda mtf or the syncromesh.
