What Turbo Would Everyone Recommend for a ZC Motor?
Old May 28, 2002 | 12:52 PM
CRXMATT's Avatar
Default What Turbo Would Everyone Recommend for a ZC Motor?
Everyone keeps telling me Greddy, If I use a greddy how much horse will it add?
[Modified by CRXMATT, 9:52 PM 5/28/2002]
Old May 28, 2002 | 01:37 PM
Jared's Avatar
Default Re: What Turbo Would Everyone Recommend for a ZC Motor? (CRXMATT)
The GReddy kit is a simple install but its a very small turbo that is limited in airflow. Check out a kit with a bigger turbo, like a T3, from Rev hard or Drag.
Old May 28, 2002 | 01:51 PM
AMChev's Avatar
If you aren't going to build the engine for boost then the Greddy kit is safest... I'd get a Zdyne ECU though... screw all that manual engine management.
Old May 28, 2002 | 03:39 PM
Okay20's Avatar
For the most power go with DRAG Gen 3 Turbo Kit. You can find it at http://www.importparts.com for about $3200 for your car. Hope I helped.
Old May 29, 2002 | 10:54 AM
big pete's Avatar
Default Re: What Turbo Would Everyone Recommend for a ZC Motor? (LegallyBrown786)
id rather piece together my own kit for about 2000 and have better stuff than the drag kit
Old May 29, 2002 | 11:48 AM
solo2crx's Avatar
Custom is the way to go with the Zydne SECU.
T25 turbo from a second gen Eclipse GS-T and some others = quick spool = almost instant boost and power = very quick street car.
14b turbo from a 1st gen Eclipse Turbo and some others = slightly slower spool = a little lag but more boost (higher psi) available in the long run = more more power in the long run if built right = good for drag applications on small bore motors and fast street cars with very little engine build up.
16 and 18 mitsu turbos, t3/t4 setups, and other setups I have less info on so will only coment that they all act a little different in terms boost levels and spool time some need higher levels of engine build up and intercooling.
I know the T25 and 14b will bolt up rather easily in a CRX or Civic with a d16a6 or ZC. Some folks use adapter plates with HF manifolds, some use just the HF mani, some use custom manifolds. just depends on how much cheese you have in your pockets.
HTH a little
Goble
Dec 7, 2004 07:59 AM
pelotudo
Aug 11, 2002 06:02 PM
RR98DX
Apr 20, 2002 07:40 AM
-=TWITCH=-
12
Jan 15, 2002 09:49 PM
