JDM Headlights Wiring Question
Old Apr 17, 2007 | 11:12 AM
B18 Piston's Avatar
Default JDM Headlights Wiring Question
I just finished wiring JDM Headlights on my teggy. evertything works fine. only one thing, then I swithch on Low Beam nothin else works.... here it is
thats what Im looking for:
what should I do? thanks
p.s. searched
Old Apr 17, 2007 | 11:17 AM
B18CJDM ITR's Avatar
Default Re: JDM Headlights Wiring Question (TYPERRER)
you what the center "fogs" to work along with what eleS?
Old Apr 17, 2007 | 11:22 AM
B18 Piston's Avatar
Default Re: JDM Headlights Wiring Question (B18CJDM GSR)
i need: low beam + yellow fogs + side marks + turn signals too
Old Apr 17, 2007 | 11:23 AM
cdntegintx's Avatar
yea exactly, the inner yellow lights are the fog lights. You can wire those up separatly to a switch to turn them on and off whenever you wish. The turn signals aren't lit up either though. You're just going to have to go to the source and see what the problem is, track wires and connect them where needed. The turn signals should be lit up as the same time as the corner lights on the USDM fronts, so you can track down where that harness is and get power from that.
Old Apr 17, 2007 | 11:44 AM
00ITR #543's Avatar
Default Re: (cdntegintx)
fogs are to be with a relay to the battery and a foglight switch. You take the switching power source from the parking/city light. I tried wiring the side signal lights so that they signal as well and have the same thing happen with the sidemarker lights. I was able to do this with the usdm front, but you can't do it with the JDM ITR front, because the front signal bulbs are not dual filament and do not take 2 power sources (parking and signal). It is either parking light or signal, which is the same case with the sidemarker lights, which are single filament as well. I went ahead and wired my sidmarker lights to coincide with the parking lights and the front corner lights to signal.
Old Apr 17, 2007 | 11:02 PM
B18 Piston's Avatar
thanks guys
deucedeuceEK
May 5, 2010 10:34 AM
JmurGSR98
Mar 12, 2008 03:08 PM
I AM WEASEL
Oct 8, 2007 11:34 AM
gribbs
Jul 9, 2004 01:34 PM
