crank work
Old Apr 17, 2007 | 06:06 AM
rasta420's Avatar
Default crank work
im in the process of rebuilding my d16a6, and i wanted to send my crankshaft out to get micropolished. is there a company on honda-tech that offers these services at good prices? i tried looking through the performance forum but couldnt find anything.
Old Apr 17, 2007 | 06:07 AM
CRX Toad's Avatar
Default Re: crank work (rasta420)
I would suggest a local machine shop. They will be able to do it for you. It is VERY expensive to ship cranks.
Where are you at?
Old Apr 17, 2007 | 06:21 AM
rasta420's Avatar
Default Re: crank work (CRX Toad)
im near DC...
Old Apr 18, 2007 | 10:25 AM
rasta420's Avatar
someone told me that the machine shop will also be able to tell what size bearings i will need to use, just from the crank. is this true? or will they need the rods and main bearing cap in order to do so?
Old Apr 18, 2007 | 10:30 AM
cr-x-91's Avatar
it depends if they machine the main journals or line bore ur new rods out...they always mark the cran on the balencer it should say like 20/20 one for the mains and the other for the rod...they tell u standard oversize or undersize..
king06
Jan 7, 2015 03:37 PM
rasta420
Apr 18, 2007 12:05 PM
error
Jan 20, 2006 03:43 PM
93LSivic
Aug 5, 2002 01:44 PM
