b16 turbo and tranny question
wow. Why dont you search and find out. You need a b16 full swap, and then a turbo. Anywhere between 2k and 10k. Just depends on what you buy.
you didnt search otherwise, you would have the answer. I am not being a dick, but seriously, your question is way to broad, and the answers are out there, you just need to find them.
For instance: a b16 swap from Hmotors online cost around $2500, full swap. You might find it cheaper local, or from somewhere else, but we will use that for now. If you would have searched for an engine, you would have found this.
Then the turbo. You can build your own junkyard turbo for under $1000, or buy a bolt-on one for around $3000, or go all out and get a really nice kit for alot more.
Then are you going to leave the motor stock, or build it?
Like I said, your question is too broad, and even if you get specific, then you still need to put some effort into it and search around.
im going to agree with sol2hatch, do a little research find a b series swap than find some turbo parts, check out homemadeturbo.com people sell all types of turbo **** off there. but come on are you using the internet for **** or something when your asking about a turbo and motor swap. figure full motor swap is around i dunno 1500-2000 never did one so im not sure i turboed my d series for under 1500 and the only off brand part was the fmic from ebay and the only thing id need to put it on a b series is a manifold so use the noodle thats why we have one
xwhitchx
29
Mar 10, 2010 08:28 AM
